[mapserver-users] confused about using GridObj
    Venkat Rao Tammineni
    vtammineni at roulacglobal.com
    Tue May  5 05:07:49 PDT 2009
GridObj Class
Constructor
The grid is always embedded inside a layer object defined as a grid
(layer->connectiontype = MS_GRATICULE)
 (for more docs : http://trac.osgeo.org/mapserver/wiki/MapServerGrid)
A layer can become a grid layer by adding a grid object to it using :
ms_newGridObj(layerObj layer)
$oLayer = ms_newlayerobj($oMap);
$oLayer->set("name", "GRID");
ms_newgridobj($oLayer);
$oLayer->grid->set("labelformat", "DDMMSS");
Type 	Name
double 	minsubdivide
double 	maxsubdivide
double 	minarcs
double 	maxacrs
double 	mininterval
double 	maxinterval
string 	labelformat
Methods
int set(string property_name, new_value)
    Set object property to a new value.
Thanks,
Venkat
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Ahmet Temiz
Sent: Tuesday, May 05, 2009 5:30 PM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] confused about using GridObj
hello
I am confused about using GridObj in java-mapscript
Is there any example code containing
gridobj in java-mapscript
regards
Ahmet Temiz
Open WebMail Project (http://openwebmail.org)
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users
