[mapserver-users] problem in reference map
Venkat Rao Tammineni
vtammineni at roulacglobal.com
Mon May 11 01:24:54 EDT 2009
This one u should place in mapfile
###################### Refrence Map #####################
REFERENCE
STATUS on
IMAGE "..\images\india-map_small.png"
SIZE 120 80
EXTENT 64.881 5.469 97.898 37.762
STATUS OFF
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
# MAXBOXSIZE 125
END
########### INCLUDE MAP FILE AREA################
This is my C# code for generating Refrence map.same time you need to have
one temp folder with will store the temp images
public void LoadLegend(System.Web.UI.WebControls.ImageButton imgleg)
try
string imageLoc;
string imageURL;
imageObj imgRef;
imgRef = MapFunction.Map.drawReferenceMap();
imageLoc = MapFunction.OutputDir + "/" +
System.DateTime.Now.ToBinary() + "." + imgRef.format.extension; // here u
need to store images in temp forlder
imageURL =
imageLoc.Substring(imageLoc.IndexOf(MapFunction.OutputDirURL)); // here u
need to give the image url
imgRef.save(imageLoc, null);
imgleg.Width = imgRef.width;
imgleg.Height = imgRef.height;
imgleg.ImageUrl = "../" + imageURL;
MapFunction.IsMapInDirectory = false;
catch (Exception exp) { }
This is working for me in C#.I think it will give some idea.
Thanks,
Hyderbad
India
-----Original Message-----
Sent: Friday, May 08, 2009 10:55 PM
To: Venkat Rao Tammineni; 'Steve Lime'; mapserver-users at lists.osgeo.org
Subject: RE: [mapserver-users] problem in reference map
Thank you
I am using java. However, I try to adapt C# to java
On Fri, 8 May 2009 12:46:09 +0530, Venkat Rao Tammineni wrote
> HI,
> Which language you are using ...if it is C# , then I can help you.
> Thanks
> Venkat
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Ahmet Temiz
> Sent: Friday, May 08, 2009 12:39 PM
> To: Steve Lime; mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] problem in reference map
> On Thu, 07 May 2009 12:26:47 -0500, Steve Lime wrote
> thank you
> reference map extent is same as main map extent.
> I checked size of reference map.
> But the problem still exists.
> > Most likely your reference map size or extent are incorrect. That's
> > where I'd start.
> > Steve
> > >>> On 5/7/2009 at 6:54 AM, in message
> <20090507115038.M79754 at deprem.gov.tr>,
> > "Ahmet Temiz" <temiz at deprem.gov.tr> wrote:
> > > hello
> > > the red box in my reference map isn't settled on my zoomed main map.
> > > what am I likely to miss ?
> > > regards
> > > Ahmet Temiz
> > > Open WebMail Project (http://openwebmail.org)
> > This message has been scanned for viruses and
> > dangerous content by MailScanner, and is
> > believed to be clean.
