[mapserver-users] Get the nearest layer with mapscript...
Fawcett, David
David.Fawcett at state.mn.us
Wed May 20 09:44:45 EDT 2009
Paul,
I would guess that this really is about the client-side map interface and not about MapServer. Does your interface only allow them to click/select the topmost layer? Do you pick which layer is selectable? Do you let them pick which layer is selectable? Is it random?
Tells us more about the client-side app.
David.
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Paul james
Sent: Wednesday, May 20, 2009 7:55 AM
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Get the nearest layer with mapscript...
Thanks Pano...
But It´s not that simple...
What I need is figure out what LAYER was clicked...
Paul
On Wed, May 20, 2009 at 6:43 AM, Pano Voudouris <pvoudouris at gaiocorp.com> wrote:
Probably don't understand what exactly you are trying to achieve here but it is not as simple as map.getLayer(0) to get the topmost layer? And once you have the layer object use one of the query function to select the record? E.g. myLayerObj.queryByPoint ?
Pano
Sent: 19 May 2009 21:46
Subject: [mapserver-users] Get the nearest layer with mapscript...
Hello guys...
I have several layers (lines, points, poly) ...
I´m developing a measure tool... User can click on map and I have to select that layer to calculate de Area with postgis...
I´m trying to do that WITHOUT using "LAYER ACTIVE SYSTEM"...
Is That possible using mapscript? How Can I find the nearest and toppest layer ?
Thanks!
Paul
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090520/540e6020/attachment-0001.html
