[mapserver-users] GRIB files - gdal_translate
Jose Roberto M. Garcia, MSc
roberto.garcia at cptec.inpe.br
Thu May 21 08:34:56 EDT 2009
I opened the tif file I've extracted form it in QGIS and it looked like
the same thing, a line. What do I need to do to manipulate this as a
tiled/blocked data so? I want both things: make mapserver renders direct
from the GRIB file and either create GeoTiff files from them using
gdal_translate, by this time.
Tks a lot
Ivan wrote:
> Hi there!
> There is nothing wrong with your block X and Y size (161x1). It
> indicates that your data is not tiled/blocked, so it is most likely to
> be read row by row. If the image looks strange is not because of that.
> You have 98 rows in 0.02 degrees, so if it looks like a line, I
> wouldn't be suprised. Have you try to open it in another GDAL based
> client application, like QGIS for example?
> Regards,
> Ivan
> Roberto Garcia,MSc wrote:
>> Hi people,
>> I used gdal_translate in the GRIB file I want to show with mapserver,
>> but there still is something wrong. The following is a partial output
>> from it:
>> Driver: GRIB/GRIdded Binary (.grb)
>> Files: data\raster\T126L28.grb
>> Size is *161, 98*
>> Coordinate System is:
>> Origin = (-150.000000000000000,-61.246000000000002)
>> Pixel Size = (0.938000000000000,-0.001836734693878)
>> Corner Coordinates:
>> Upper Left (-150.0000000, -61.2460000) (150d 0'0.00"W, 61d14'45.60"S)
>> Lower Left (-150.0000000, -61.4260000) (150d 0'0.00"W, 61d25'33.60"S)
>> Upper Right ( 1.0180000, -61.2460000) ( 1d 1'4.80"E, 61d14'45.60"S)
>> Lower Right ( 1.0180000, -61.4260000) ( 1d 1'4.80"E, 61d25'33.60"S)
>> Center ( -74.4910000, -61.3360000) ( 74d29'27.60"W, 61d20'9.60"S)
>> Band 1 Block=*161x1* Type=Float64, ColorInterp=Undefined
>> Description = 0[-] MSL (Mean sea level)
>> Metadata:
>> GRIB_UNIT=[Pa]
>> GRIB_COMMENT=Pressure reduced to MSL [Pa]
>> GRIB_ELEMENT=PRMSL
>> GRIB_SHORT_NAME=0-MSL
>> GRIB_REF_TIME= 1242453600 sec UTC
>> GRIB_VALID_TIME= 1242453600 sec UTC
>> GRIB_FORECAST_SECONDS=0 sec
>> As u can see the size according to the its header is 161x98, but all
>> the bands are related as 161x1 block. Why does it happen? Another
>> thing I noticed is that the dif between upper and lower latitude in
>> the corner coordinates is very small (-61.246 to -61.426).
>> The issue is that, when mapserver renders this layer it only draws a
>> straight line below South America, exactly where the whole image
>> should start, as my CTL below shows.
>> dset ^T126L28.grb
>> title pac/sa/atlan sector: troposphere file
>> undef 1e+20
>> dtype grib
>> index ^T126L28.gmp
>> xdef 161 linear -150.000015 0.937500
>> ydef 98 levels
>> -61.246 -60.311
>> -59.376 -58.441 -57.506 -56.571 -55.636 -54.701 -53.766 -52.831
>> -51.896 -50.961
>> -50.026 -49.091 -48.156 -47.221 -46.286 -45.350 -44.415 -43.480
>> -42.545 -41.610
>> -40.675 -39.740 -38.805 -37.870 -36.935 -36.000 -35.065 -34.130
>> -33.195 -32.260
>> -31.325 -30.389 -29.454 -28.519 -27.584 -26.649 -25.714 -24.779
>> -23.844 -22.909
>> -21.974 -21.039 -20.104 -19.169 -18.234 -17.299 -16.364 -15.429
>> -14.493 -13.558
>> -12.623 -11.688 -10.753 -9.818 -8.883 -7.948 -7.013 -6.078
>> -5.143 -4.208
>> -3.273 -2.338 -1.403 -0.468 0.468 1.403 2.338 3.273
>> 4.208 5.143
>> 6.078 7.013 7.948 8.883 9.818 10.753 11.688 12.623
>> 13.558 14.493
>> 15.429 16.364 17.299 18.234 19.169 20.104 21.039 21.974
>> 22.909 23.844
>> 24.779 25.714 26.649 27.584 28.519 29.454
>> zdef 7 levels
>> 1000 925 850 700 500 300 200 ===> set Z 1 ou 2 ou 3 ... ou 7 (GRADS)
>> tdef 1 linear 6Z16may2009 6hr
>> vars 15
>> psnm 0 2,102, 0, 0 SEA LEVEL PRESSURE [hPa]
>> tsfc 0 187, 1, 0, 0 SURFACE TEMPERATURE [K]
>> prec 0 61, 1, 0, 0 TOTAL PRECIPITATION [Kg/m2/day]
>> cbnv 0 71, 3, 0, 0 CLOUD COVER [0-1]
>> role 0 114, 8, 0, 0 OUTGOING LONG WAVE AT TOP [W/m2]
>> mask 7 137,100 MASK [-/+]
>> uvel 7 33,100 ZONAL WIND (U) [m/s]
>> vvel 7 34,100 MERIDIONAL WIND (V) [m/s]
>> omeg 7 39,100 OMEGA [Pa/s]
>> fcor 7 35,100 STREAM FUNCTION [m2/s]
>> potv 7 36,100 VELOCITY POTENTIAL [m2/s]
>> zgeo 7 7,100 GEOPOTENTIAL HEIGHT [gpm]
>> temp 7 11,100 ABSOLUTE TEMPERATURE [K]
>> umrl 7 52,100 RELATIVE HUMIDITY [no Dim]
>> umes 7 51,100 SPECIFIC HUMIDITY [kg/kg]
>> endvars
>> Can someone help me to find out what is happening?
>> Tks a lot
>> Roberto Garcia
>>>> Hi, tks for the answers.
>>>> According to my gdainfo output file attached, can anyone tell me
>>>> what element could be a CLASSITEM?
>>> Roberto,
>>> In MapServer you always classify rasters based on the item [pixel] but
>>> you do not need to explicitly state a classitem.
>>> This is a relatively simple example of raster classification.
>>> LAYER
>>> NAME grid1
>>> TYPE raster
>>> STATUS default
>>> DATA data/float.tif
>>> CLASS
>>> NAME "red"
>>> EXPRESSION ([pixel] < -3)
>>> COLOR 255 0 0
>>> END
>>> CLASS
>>> NAME "green"
>>> EXPRESSION ([pixel] >= -3 and [pixel] < 3)
>>> COLOR 0 255 0
>>> END
>>> CLASS
>>> NAME "blue"
>>> EXPRESSION ([pixel] >= 3)
>>> COLOR 0 0 255
>>> END
>>> END
>>>> I can see my grib using Grads but what tool do I use to translate
>>>> individual bands into GeoTIFF?
>>> You can use gdal_translate to extract particular bands from a grib file
>>> as a geotiff (or all the bands). For instance, the following would
>>> extract band 3 (total precipitation):
>>> gdal_translate -b 3 T126L28.grb total_precip.tif
>>>> Converting the data on-the-fly to an image is the right way to work?
>>> Having MapServer access the grib file on the fly rather than depending
>>> on pre-translated extracts will reduce data duplication and may help
>>> avoid confusion about what is up to date. However, it is possible that
>>> there will be a performance penalty for extracting directly from GRIB.
>>> If so, it may not be significant enough to matter to you.
>>>> What are the problems with Apache if I do not do so?
>>> I don't see how either approach relates to Apache. It is a
>>> data management and possibly performance issue with MapServer.
>>> Best regards,
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
Jose Roberto M. Garcia, Msc
Grupo Banco de Dados / CPTEC / INPE
Fone: (12) 3186-8405
A luta contra o aquecimento global depende de cada um de nós, faça sua parte, economize recursos naturais.
http://www.cptec.inpe.br
http://www.inpe.br
