[mapserver-users] Oracle Spatial and "styleitem auto"
Jelmer Baas
Baas at speerit.nl
Sun May 24 15:22:32 EDT 2009
Tamas,
Thanks to your url I managed to get it working. The performance is way
better than I hoped! The only thing that doesn't seem to work is
linewidth for (poly)lines. The style
PEN(w:8px,c:#FF6A00) still draws a 1 or 2 pixel line. I tried using cm,
pt, etc, but that doesn't change anything.
I don't have a style in my map file that overrides it, too (only a class
with name and template).
Any ideas? Or should I ask this question in a gdal/ogr list?
Regards,
Jelmer Baas
From: Tamas Szekeres [mailto:szekerest at gmail.com]
Sent: zaterdag 23 mei 2009 0:30
To: Jelmer Baas
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Oracle Spatial and "styleitem
auto"
If you are using OGR to access the Oracle Spatial data source,
you could specify a valid OGR style string in the table by adding field
with name: 'OGR_STYLE'.
In this case OGR will extract the feature style automatically
when using the STYLEITEM "AUTO" option with this OGR layer.
For more information about the OGR feature style strings see:
http://www.gdal.org/ogr/ogr_feature_style.html
You could use ogr2ogr to transfer the feature styles between
various data sources, see the document above.
Best regards,
Tamas
2009/5/22 Jelmer Baas <Baas at speerit.nl>
Hello List,
Are there any plans to create a way for MapServer to
automaticly apply a
certain style to data retrieved from Oracle Spatial? For
example by
specifying a style column in the mapfile which contains
a MapInfo style
description?
With kind regards,
Jelmer Baas
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090524/41579ea4/attachment.html
