[mapserver-users] MapServer Demo
Brent Fraser
bfraser at geoanalytic.com
Tue May 26 15:52:06 EDT 2009
Try removing the leading "/" from "/C:", to get:
var snippet = "IMAGEPATH 'C:/ms4w/tmp/ms_tmp/'";
Chris Green wrote:
> David
> Thanks for the suggestion, but that doesn’t do it – same error message.
> I have been wondering if the problem has to do with the tmp file not
> having permission for other (web-based) users to access it, but I tried
> declaring it as a system environment variable, still no success. Going
> round in circles now…..
> Chris
> *From:* Fawcett, David [mailto:David.Fawcett at state.mn.us]
> *Sent:* Tuesday, May 26, 2009 7:43 PM
> *To:* chris.green at ibstv.co.uk; mapserver-users at lists.osgeo.org
> *Subject:* RE: [mapserver-users] MapServer Demo
> Chris,
> Try snippet += " IMAGEURL '/tmp/'
> David.
> -----Original Message-----
> *From:* mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] *On Behalf Of
> *Chris Green
> *Sent:* Tuesday, May 26, 2009 11:56 AM
> *To:* mapserver-users at lists.osgeo.org
> *Subject:* [mapserver-users] MapServer Demo
> Hi All
> I have a problem that I can see has been experienced by others, but
> the advice given to those others does not fix my problem. I have
> successfully installed Map Server and Apache onto winXP using ms4W,
> and downloaded the Demo. I put the workshop-5.0 directory in the
> Apache.htdocs directory, and I have modified the index.html file and
> Itasca.map files in what seems to be a logical way.
> My problem is that when I launch the application I get the error
> message: “msSaveImageGD(): Unable to access file. Unable to open
> file /C:/ms4w/tmp/ms_tmp/ITASCA12433555452596.png for writing”. It
> seems that this is related to the way that I modified the index.html
> file, which I did as follows:
> var snippet = "IMAGEPATH '/C:/ms4w/tmp/ms_tmp/'";
> snippet += " IMAGEURL '/ms-tmp/'";
> I have been tearing my hair out for a few hours trying to see what I
> have done wrong. Anyone got any suggestions please?
> Chris Green
