[mapserver-users] Mapserver/PostGIS map file problem (double
quotes in layer 'DATA' element)
Adam Eskreis
aeskreis at gmail.com
Wed May 27 18:51:13 EDT 2009
You could try regex
\"Area\"
-Adam
On Wed, May 27, 2009 at 6:48 PM, Peter Willis <peterw at borstad.com> wrote:
> Hello,
> I am having a problem serving a PostGIS layer via mapserver
> as WFS.
> The problem arises from the generation/use of column names
> in PostgreSQL that require double quotes.
> ie:
> SELECT oid,gid, the_geom, "Area","Perimeter","PixelValue" FROM
> global_Land_poly WHERE "PixelValue"=1;
> In the map file the 'DATA' member of the PostGIS layer is defined as:
> DATA "the_geom from (select oid,gid, the_geom, Area,Perimeter,PixelValue
> FROM global_Land_poly WHERE PixelValue=1 ) AS FOO using SRID=4326"
> <ERR>Mapserver relays a PostGIS error from PostgreSQL:
> 'ERROR: column "area" does not exist...</ERR>
> This is because the column name is actually "Area"
> and requires quotes.
> How do I define double quotes in my PostGIS query
> within the 'DATA' element of my mapfile layer?
> Thanks for any enlightenment,
> Peter
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090527/3e15e921/attachment.html
