[mapserver-users] Point lables and tiles
paalkr
pal.kristensen at statkart.no
Thu May 28 09:36:19 EDT 2009
Hi!
OK, are there any methods that could be used to let MapServer produce a
bigger image and then chop off excess area before sending the image to the
client? I think that this would be the easiest and most flexible solution.
Regards,
Pål Kristensen
Thomas Bonfort-2 wrote:
> it doesn't put any labels in the 10 outermost pixels surrounding the
> generated image (as they are chopped off by tilecache's metabuffer)
> thomas
> www.camptocamp.com
> +33 4 79 26 57 97
> On Mon, May 25, 2009 at 16:45, paalkr <pal.kristensen at statkart.no> wrote:
>> Hi!
>> Thanks for the hint! The problem is that I'm using GeoWebCache and not
>> tilecache :) Is the
>> METADATA
>> labelcache_map_edge_buffer "-10"
>> END
>> a MapServer keyword? What does it do exactly?
>> Any other possible solutions?
>> Regards,
>> Pål Kristensen
>>> http://lists.osgeo.org/pipermail/mapserver-users/2009-March/060214.html
>>> regards,
>>> thomas
>>> www.camptocamp.com
>>> +33 4 79 26 57 97
>>> On Mon, May 25, 2009 at 15:00, paalkr <pal.kristensen at statkart.no>
>>> wrote:
>>>> Hi!
>>>> When creating tiles for my tilecache I have some issues regarding point
>>>> labels. Using the PROCESSING label_no_clip=true works for line and
>>>> polygon
>>>> labels, but points has not area/size and will therefor newer be present
>>>> in
>>>> two neighbouring tiles. The result are clipped labels because only one
>>>> tile
>>>> will ever know about the presence of a point. If then the label should
>>>> have
>>>> been rendered into the next tile, it will be clipped. Metatiles
>>>> (requesting
>>>> more than one tile at a time and splitting it up on the tile server)
>>>> helps,
>>>> but only a little, as the same problem will occur between metatiles.
>>>> A solution would be that MapServer rendered each tile (map) some
>>>> percentage
>>>> larger than requested, and then chops of the excess area before
>>>> delivering
>>>> the final map. A setting at the MAP level of the mapfile controlling
>>>> this
>>>> "grow" mechanism would be great, defining the percentage the map shall
>>>> be
>>>> extended before rendering.
>>>> Second, is there any other way to solve the issue? Especially if there
>>>> are
>>>> already features in MapServer that can be used.
>>>> Regards,
>>>> Pål Kristensen
>>>> Regards,
>>>> Pål Kristensen
>>>> View this message in context:
>>>> http://n2.nabble.com/Point-lables-and-tiles-tp2969528p2969528.html
>>>> Sent from the Mapserver - User mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> mapserver-users mailing list
>>>> mapserver-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> Regards,
>> Pål Kristensen
>> http://n2.nabble.com/Point-labels-and-tiles-tp2969528p2969950.html
Regards,
Pål Kristensen
View this message in context: http://n2.nabble.com/Point-labels-and-tiles-tp2969528p2987684.html
