[mapserver-users] Upgrading 5.2 -> 5.4 generating CGI error...
Paul james
pauljame at gmail.com
Thu May 28 16:43:26 EDT 2009
I got that error when try to enter :
http://localhost/cgi-bin/mapserv.exe?map=C:/map.map
CGI ErrorThe specified CGI application misbehaved by not returning a
complete set of HTTP headers. The headers it did return are:
My Map:
MAP
EXTENT -79.7892 -34.2426 -24.9958 6.11775
FONTSET "Fonts\Fonts.txt"
IMAGECOLOR 230 254 254
IMAGETYPE png
SIZE 800 600
STATUS ON
UNITS dd
NAME "Test"
OUTPUTFORMAT
NAME "png"
MIMETYPE "image/png"
DRIVER "GD/PNG"
EXTENSION "png"
IMAGEMODE "PC256"
TRANSPARENT FALSE
END
PROJECTION
'proj=longlat'
'ellps=WGS84'
'datum=WGS84'
'no_defs'
END
WEB
IMAGEPATH 'C:\map\temp'
IMAGEURL '/tmp/'
QUERYFORMAT text/html
LEGENDFORMAT text/html
BROWSEFORMAT text/html
END
QUERYMAP
COLOR 255 0 0
SIZE -1 -1
STATUS ON
STYLE hilite
END
REFERENCE
STATUS on
SIZE 221 150
MINBOXSIZE 5
MAXBOXSIZE 150
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
MARKERSIZE 8
END
LAYER
NAME Test
GROUP "Tests"
TYPE POLYGON
STATUS default
CONNECTIONTYPE POSTGIS
CONNECTION "user=xpassword=xdbname=x host=x port=5432"
DATA "the_geom from viwgeo_x USING UNIQUE oid USING SRID=-1"
CLASS
COLOR 255 0 255
END
END
END
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090528/213cc436/attachment.html
