[mapserver-users] Re: Upgrading 5.2 -> 5.4 generating CGI error
on IIS(5.1 and 6.0) ... Possible BUG?
Paul james
pauljame at gmail.com
Fri May 29 14:08:00 EDT 2009
http://localhost/cgi-bin/mapserv.exe?map=C%3A%2Finetpub%2Fwwwroot%2FOpenlayer%2FFiles%2FMapserver%2FMap.map&mode=map&map_imagetype=png&mapext=-180+0+-90+90&imgext=-180+0+-90+90&map_size=256+256&imgx=128&imgy=128&imgxy=256+256
Paul
On Fri, May 29, 2009 at 3:01 PM, Steve Lime <Steve.Lime at dnr.state.mn.us>wrote:
> What's the full URL submitted against the CGI?
> >>> On 5/29/2009 at 12:59 PM, in message
> <33fad6880905291059i5602a89q84d7673ddcfff511 at mail.gmail.com>, Paul
> james
> <pauljame at gmail.com> wrote:
> > 1 - I tried with 1500,1400,1310,development version(1500) and ms4w
> beta...
> > 2 - Ím using normal CGI
> > 3 - My tests are only with Postgis... Íll generate a shapefile to
> test
> > later ...
> > Paul
> > On Fri, May 29, 2009 at 2:27 PM, Tamas Szekeres <szekerest at gmail.com>
> wrote:
> >> Hi Paul,
> >> Did you experience the same with the release-1310 and release-1400
> >> versions? Did you experience the same with the development version?
> >> Are you using fastCGI or normal cgi?
> >> Is this just a PostGIS related problem or you get the same with a
> simple
> >> shapefile?
> >> Sorry for the bunch of the questions...
> >> Best regards,
> >> Tamas
> >> 2009/5/29 Paul james <pauljame at gmail.com>
> >>> Yes Daniel... I deleted all previous files and put only 5.4
> files... My
> >>> mapscript application is working fine on 5.4...
> >>> But the CGI dont...
> >>> Tested on Windows XP (IIS 5.1) and Windows 2003(IIS 6.0)...
> >>> Paul
> >>> On Fri, May 29, 2009 at 12:56 PM, Daniel Morissette <
> >>> dmorissette at mapgears.com> wrote:
> >>>> Paul james wrote:
> >>>>> Hi Daniel...
> >>>>> I got the binaries from Tamas build :
> >>>>> http://vbkto.dyndns.org:1280/sdk/Default.aspx
> >>>>> And from MS4W 3.0 beta2...
> >>>>> Same result with both...
> >>>>> That error you got is my fault... I took off the :
> >>>>> IMAGE "..\Map.png"
> >>>>> from REFERENCE definition when copy the code to email...
> >>>>> My application works fine with 5.2 binary in iis 5.1 and 6.0
> >>>>> Just replacing with 5.4 binary I got that 502 error...
> >>>> Hopefully you always make sure you update all DLLs as well when
> you
> >>>> "replace with 5.4 binary"? Even if the DLLs have the same names,
> if they
> >>>> come from different build environments or versions they may not
> be
> >>>> compatible and could cause the kind of crashes that you are
> experiencing.
> >>>> Daniel
> >>>> Daniel Morissette
> >>>> http://www.mapgears.com/
> >>> _______________________________________________
> >>> mapserver-users mailing list
> >>> mapserver-users at lists.osgeo.org
> >>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090529/2473531a/attachment.html
