[mapserver-users] Query feature using openlayers and mapserver
    Aypes
    apestgas at yahoo.com.hk
    Mon Nov  2 17:49:35 PST 2009
I have solved the problem. There is the function code in my html:
 map.events.register('click', map, function (e) {
    var url = "http://localhost/cgi-bin/mapserv.exe"
      + "?map=map/file/directory.map"
      + "&REQUEST=GetFeatureInfo"
      + "&VERSION=1.1.1"
      + "&EXCEPTIONS=application/vnd.ogc.se_xml"
      + "&BBOX="
      + map.getExtent().toBBOX()
      + "&X=" + e.xy.x
      + "&Y=" + e.xy.y
      + "&INFO_FORMAT=text/html"
      + "&QUERY_LAYERS=querylayer"
      + "&LAYERS=querylayer"
      + "&FEATURE_COUNT=1"
      + "&SRS=EPSG:4269"
      + "&STYLES="
      + "&WIDTH=" + map.size.w
      + "&HEIGHT=" + map.size.h;
    window.open(url,
      "getfeatureinfo",
      "location=0,status=0,scrollbars=1,width=600,height=400"
But if I turn off the layer, I click on the map, a new window still come
out. That is not the problem. The problem is the turned off layer can still
be queried. I want that the turned off layer is not queryable.
New window can still come out without any information. Please give me a
hand.
Thanks,
Aypes
View this message in context: http://n2.nabble.com/Query-feature-using-openlayers-and-mapserver-tp3910093p3936077.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
More information about the MapServer-users
