AW: [mapserver-users] Query feature using openlayers and mapserver
Aypes apestgas at yahoo.com.hk
Tue Nov 3 20:06:55 PST 2009
Arnd Wippermann wrote:
> Hi,
> Look for the visibility of your "querylayer" and decide what to do
> map.events.register('click', map, function (e)
>     var flag=map.getLayersBy("name", "querylayer")[0].visibility;
>     if(flag)
>         var url = "http://localhost/cgi-bin/mapserv.exe"
>           + "?map=map/file/directory.map"
>           + "&REQUEST=GetFeatureInfo"
>           + "&VERSION=1.1.1"
>           + "&EXCEPTIONS=application/vnd.ogc.se_xml"
>           + "&BBOX="
>           + map.getExtent().toBBOX()
>           + "&X=" + e.xy.x
>           + "&Y=" + e.xy.y
>           + "&INFO_FORMAT=text/html"
>           + "&QUERY_LAYERS=querylayer"
>           + "&LAYERS=querylayer"
>           + "&FEATURE_COUNT=1"
>           + "&SRS=EPSG:4269"
>           + "&STYLES="
>           + "&WIDTH=" + map.size.w
>           + "&HEIGHT=" + map.size.h;
>         window.open(url, "getfeatureinfo",
> "location=0,status=0,scrollbars=1,width=600,height=400");
> Regards,
> Arnd
> -----Ursprüngliche Nachricht-----
> Von: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] Im Auftrag von Aypes
> Gesendet: Dienstag, 3. November 2009 02:50
> An: mapserver-users at lists.osgeo.org
Arnd Wippermann,
Thanks for your answer. I get your idea, but it does not work.
It said "map.getLayersBy(...) is null or not an object.
I want to ask in [map.getLayersBy("name", "querylayer")[0].visibility], what
is the "name"?
If I create a layer like that:
var ABC_layer = new OpenLayers.Layer.MapServer( "ABC WMS",
"http://localhost/cgi-bin/mapserv.exe?map=c:/ms4w/Apache/htdocs/map.map&",
{layers: 'ABC'} );
The "name" is ABC WMS, ABC or ABC_layer?
Actually I have written in this way:
.....function (e) {
    if (ABC_layer.visibility == true) {
    var url.....
It works but this part of codes only for one layer only. If there are many
layers, the html file would be looked clumsy.
Thanks,
Aypes
View this message in context: http://n2.nabble.com/Query-feature-using-openlayers-and-mapserver-tp3910093p3943083.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
More information about the MapServer-users mailing list
