[mapserver-users] Designing a wrapper around mapserv which can be used with fcgi
Adrian Popa
adrian_gh.popa at romtelecom.ro
Tue Nov 3 23:14:37 PST 2009
Thank you Andy for explaining.
Actually my wrapper is very hard-core, meaning I don't use mapscript
(because I had to build it quickly and didn't have time to research
which was the best approach). Now I have more time and I'd like to tune
things up, so I will definitely start studying mapscript (If you have a
link to a good tutorial/function reference for it I am in your debt).
My wrapper just copied over a template map file, edited it (rewrites
some filters) and then it set
$ENV{'QUERY_STRING'} = $ENV{'QUERY_STRING'}."&map=$file";
...and then called
print `/var/www/cgi-bin/mapserv`;
It's barbaric, I know, but it worked for me. :)
It will take a bit of rewrite to add fcgi support and mapscript, but in
the long run it will be more mantainable... :)
Thanks again,
Adrian
Andy Colson wrote:
>> Andy Colson wrote:
>>> Adrian Popa wrote:
>>>> Hello everyone,
>>>> I am currently using a wrapper around mapserv which receives the
>>>> URL parameters, builds the map file (actually I only need to set
>>>> some filters in the map file, but the filters need to be built
>>>> after running some SQL queries with the passed in parameters).
>>>> After the map file is built, mapserv is called (as a shell script),
>>>> and the map gets sent to the user. Currently this wrapper is
>>>> written in perl - so it's not terribly fast as a cgi process.
>>>> While this approach works, it is terribly inefficient. I would like
>>>> to use mapserv as a fcgi process (or something faster than plain
>>>> cgi). My question is - how can I /should I build a wrapper around
>>>> mapserv that can "customize" the MAP file on the fly and run as a
>>>> fcgi process?
>>>> Any ideas on where I should start? An example of such a wrapper?
>>>> Also, I suspect I can send parameters to mapserver and use some
>>>> sort of variables in the map file to set up my filters - but I
>>>> haven't seen an example. Can someone point me to such a documentation?
>>>> Thanks,
>>>> Adrian
>>> Have you seen mapscript? You can use mapserver directly from perl.
>>> And perl can do fast-cgi. Here is a little, ad-hoc, non-tested,
>>> perl fcgi:
>>> #!/usr/bin/perl
>>> use strict;
>>> use mapscript;
>>> use FCGI;
>>> my $request = FCGI::Request( );
>>> while($request->Accept() >= 0)
>>> my($req, $x, $at, $xmap, $xpin, $sid, $y, $q);
>>> $req = new mapscript::OWSRequest();
>>> $req->loadParams();
>>> $xmap = $req->getValueByName('map');
>>> $xpin = $req->getValueByName('pin');
>>> my $map = new mapscript::mapObj( "/maps/$xmap.map" );
>>> if (! $map)
>>> #print STDERR "----- Error loading map: $xmap.map\n";
>>> print("Content-type: text/text\r\n\r\n");
>>> print "cant load $xmap.map";
>>> $request->Finish();
>>> next;
>>> mapscript::msIO_installStdoutToBuffer();
>>> $x = $map->OWSDispatch( $req );
>>> if ($x)
>>> print STDERR "OWSDispatch: $x\n";
>>> my $errObj = new mapscript::errorObj();
>>> while ($errObj) {
>>> print STDERR "ERROR:
>>> $errObj->{code}:$errObj->{message}:$errObj->{routine} \n";
>>> $errObj = $errObj->next();
>>> my $content_type =
>>> mapscript::msIO_stripStdoutBufferContentType();
>>> $x = mapscript::msIO_getStdoutBufferBytes();
>>> print("Content-type: $content_type\r\n\r\n");
>>> if (mapscript::msGetVersionInt() >= 50500)
>>> print $$x;
>>> } else {
>>> print $x;
>>> mapscript::msIO_resetHandlers();
>>> $request->Finish();
>>> I'd recommend using mapserver 5.6.0.
>>> -Andy
> Adrian Popa wrote:
> > Thank you,
> > I will look into it. I guess through mapscript I can redefine the
> > parameters that get sent to mapserver? Or do I rewrite the whole map?
> You can load a map into memory (I assume you were already doing that).
> You said "..perl.. receives the URL parameters ...and... builds the
> map file".
> I assume your perl does: use mapscript?
> and at some point: my $map = new mapscript::mapObj( "/maps/$xmap.map" );
> You kind of imbed mapserver into your perl script, and can call its
> functions and what not. After you load the map you can do things to
> it, in memory.
> In my example above, I'm using the WMS features ($map->OWSDispatch),
> but you can also generate an image:
> my $img = $map->draw();
> $img->save('x.jpg', $mapscript::MS_JPG);
> -Andy
Adrian Popa
NOC Division
Network Engineer
Divizia Centrul National de Operare Retea
Departament Transport IP & Metro
Compartiment IP Core & Backbone
Phone: +40 21 400 3099
More information about the MapServer-users
