[mapserver-users] msWMSLoadGetMapParams(): WMS server error.
Jason M. Amador
jamador at sonomatech.com
Wed Nov 4 20:08:36 EST 2009
I am trying to make a WMS GetMap request in C# using the OWSRequest object but I am getting the following error.
<?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
<!DOCTYPE ServiceExceptionReport SYSTEM "http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd">
<ServiceExceptionReport version="1.1.1">
<ServiceException code="LayerNotDefined">
msWMSLoadGetMapParams(): WMS server error. Invalid layer(s) given in the LAYERS parameter.
</ServiceException>
</ServiceExceptionReport>
I can successfully make WMS GetCapabilities and GetMap requests through the browser directly. I also have no problem making a WMS GetCapabilities request in C# by using the OWSRequest object. It's just when I do a GetMap request that I get the above error.
My map file is below.
MAP
NAME CensusTract
IMAGETYPE JPEG
EXTENT -125.00 20.00 -65.00 50.00
SIZE 400 300
SHAPEPATH "C:/Inetpub/wwwroot/cgi-bin/ms4w/apps/fhwa/data/CensusTract2005"
IMAGECOLOR 255 255 255
CONFIG "PROJ_LIB" "C:/ms4w/proj/nad/"
PROJECTION
"init=epsg:4326"
END
WEB
IMAGEPATH "C:/Temp/"
IMAGEURL "/Temp/"
METADATA
"wms_title" "FHWA Census Tract"
"wms_onlineresource" "http://localhost/cgi-bin/mapserv?map=census_tract.map&"
"wms_srs" "EPSG:4269 EPSG:4326"
END
END
LAYER
NAME "censusTracts"
DATA CensusTracts
STATUS ON
TYPE POLYGON
CLASS
NAME "Census Tract"
STYLE
COLOR 232 232 232
OUTLINECOLOR 32 32 32
END
END
METADATA
"wms_name" "censusTracts"
"wms_server_version" "1.1.1"
"wms_title" "census tract"
"wms_format" "image/gif"
END
PROJECTION
"init=epsg:4326"
END
END
END
My C# code is:
OWSRequest req = new OWSRequest();
req.setParameter("SERVICE", "WMS");
req.setParameter("VERSION", "1.1.1");
req.setParameter("REQUEST", "GetMap");
req.setParameter("LAYERS", "censusTracts");
req.setParameter("BBOX", "-125.0,20.0,-65.0,50.0");
req.setParameter("SRS", "EPSG:4326");
req.setParameter("WIDTH", "400");
req.setParameter("HEIGHT", "300");
req.setParameter("FORMAT", "image/gif");
req.setParameter("STYLES", "");
mapscript.msIO_installStdoutToBuffer();
int owsResult = map.OWSDispatch(req);
Does anybody know what my issue could be or at least point me in the right direction? I have spent a lot of time researching this already and would really appreciate any help.
Thanks,
Jason
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091104/b70e6dd6/attachment-0001.html
