[mapserver-users] Re: Use of palette file: Problems with changing
colors when tiling
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Nov 6 09:17:10 EST 2009
Espen,
Try using this:
OUTPUTFORMAT
NAME agg
DRIVER "AGG/PNG"
MIMETYPE "image/png"
IMAGEMODE RGB
FORMATOPTION "INTERLACE=false"
FORMATOPTION "QUANTIZE_FORCE=ON"
FORMATOPTION "QUANTIZE_DITHER=OFF"
FORMATOPTION "QUANTIZE_COLORS=256"
FORMATOPTION "PALETTE=/data/maps/palette.txt"
END
And see if it does what you want. Also note that I use "ON" and note
"TRUE" as the value of "QUANTIZE_FORCE", but I'm not sure if the matters
or not.
-Steve
Espen Isaksen wrote:
> Yes, that is what we have been doing all along. I guess I never should
> have mentioned our testing with putting lots of colors in the palette
> file, as it just confuses people :-)
> So forget our testing, we have only put the colors we use in the
> mapfile once in the palette file(attached in the first mail), and the
> error in the color is like on the map I attached(first mail).
> Espen
> 2009/11/6 Thomas Bonfort <thomas.bonfort at camptocamp.com>:
>> Stephen Woodbridge replied to this thread, and gave the correct usage
>> of the palette file: set the same colors in your palette file as in
>> your mapfile.
>> regards,
>> thomas
>> www.camptocamp.com
>> +33 5 16 57 01 02
>> On Fri, Nov 6, 2009 at 14:24, Espen Isaksen <espen.isaksen at gmail.com> wrote:
>>> Justed wanted to bring this question into attention again since we did
>>> not get a solution to the problem, and we have not found one either.
>>> Could this possibly be a bug in Mapserver? Should we report it?
>>> Espen
>>> 2009/10/28 Espen Isaksen <espen.isaksen at gmail.com>:
>>>> Hi!
>>>> We are testing out using a palette file in our outputformat to
>>>> decrease file size in the png output. Most of the time this works
>>>> great, but some times when we are tiling the data we get some errors.
>>>> The color seem to shift to a similar color from one tile to another.
>>>> We have added the colors we use in the map file in the palette.txt
>>>> file. The documentation says it needs 256 colors in the map file, but
>>>> we do not use that many colors right now. (we tried adding the same
>>>> color more than one time, but that created other problems....)
>>>> I have attached a png file showing the problem across a lake. The
>>>> color on the right side is the correct color and the color we have
>>>> added to the palette file. The color on the left side of the lake is
>>>> not something we have set.
>>>> I have also added the palette.txt file and the outputformat we use is this:
>>>> OUTPUTFORMAT
>>>> NAME "png"
>>>> DRIVER "AGG/PNG"
>>>> IMAGEMODE "rgb"
>>>> EXTENSION "png"
>>>> FORMATOPTION "PALETTE_FORCE=TRUE"
>>>> END
>>>> Does anybody know why this happens in Mapserver and how to fix it?
>>>> Espen
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
