[mapserver-users] Re: Use of palette file: Problems with
changingcolors when tiling
Steve Lime
Steve.Lime at dnr.state.mn.us
Fri Nov 6 11:43:35 EST 2009
Correct. My palette creation process has been to:
1) create a master image that shows as many possible rendering outputs as possible as a 24-bit PNG.
2) use a tool to reduce the colors in that image to the desired number and create a 8-bit file. In my case
I use PhotoShop and produce a gif. Here's a link to the one I used for our rec. compass app but after
color reduction to 128 colors.
http://maps.dnr.state.mn.us/compass/remove/compass_color_master.gif
3) extract a palette from the 8-bit image. I wrote a little perl script that processes gdalinfo output.
4) my outputformat block is like so:
OUTPUTFORMAT
NAME png
DRIVER "AGG/PNG"
MIMETYPE "image/png"
IMAGEMODE RGB
EXTENSION "png"
FORMATOPTION "INTERLACE=OFF"
FORMATOPTION "PALETTE_FORCE=TRUE"
FORMATOPTION "PALETTE=/mapserver/compass/compass.palette"
END
I've not had problems with this method...
It's possible there's a bug but it's going to be difficult to fix without a good test case.
Steve
>>> On 11/6/2009 at 9:52 AM, in message
<a4cd3760911060752i609ad757g9872b8ff5a9b5c27 at mail.gmail.com>, Espen Isaksen
<espen.isaksen at gmail.com> wrote:
> Sorry, this still creates trouble. And you have omitted
> on this one. That means it does not use the palette file right?
> Espen
> 2009/11/6 Stephen Woodbridge <woodbri at swoodbridge.com>:
>> Espen,
>> Try using this:
>> OUTPUTFORMAT
>> NAME agg
>> DRIVER "AGG/PNG"
>> IMAGEMODE RGB
>> FORMATOPTION "INTERLACE=false"
>> FORMATOPTION "QUANTIZE_FORCE=ON"
>> FORMATOPTION "QUANTIZE_DITHER=OFF"
>> FORMATOPTION "QUANTIZE_COLORS=256"
>> FORMATOPTION "PALETTE=/data/maps/palette.txt"
>> END
>> And see if it does what you want. Also note that I use "ON" and note "TRUE"
>> as the value of "QUANTIZE_FORCE", but I'm not sure if the matters or not.
>> -Steve
>> Espen Isaksen wrote:
>>> Yes, that is what we have been doing all along. I guess I never should
>>> have mentioned our testing with putting lots of colors in the palette
>>> file, as it just confuses people :-)
>>> So forget our testing, we have only put the colors we use in the
>>> mapfile once in the palette file(attached in the first mail), and the
>>> error in the color is like on the map I attached(first mail).
>>> Espen
>>> 2009/11/6 Thomas Bonfort <thomas.bonfort at camptocamp.com>:
>>>> Stephen Woodbridge replied to this thread, and gave the correct usage
>>>> of the palette file: set the same colors in your palette file as in
>>>> your mapfile.
>>>> regards,
>>>> thomas
>>>> www.camptocamp.com
>>>> +33 5 16 57 01 02
>>>> On Fri, Nov 6, 2009 at 14:24, Espen Isaksen <espen.isaksen at gmail.com>
>>>> wrote:
>>>>> Justed wanted to bring this question into attention again since we did
>>>>> not get a solution to the problem, and we have not found one either.
>>>>> Could this possibly be a bug in Mapserver? Should we report it?
>>>>> Espen
>>>>> 2009/10/28 Espen Isaksen <espen.isaksen at gmail.com>:
>>>>>> Hi!
>>>>>> We are testing out using a palette file in our outputformat to
>>>>>> decrease file size in the png output. Most of the time this works
>>>>>> great, but some times when we are tiling the data we get some errors.
>>>>>> The color seem to shift to a similar color from one tile to another.
>>>>>> We have added the colors we use in the map file in the palette.txt
>>>>>> file. The documentation says it needs 256 colors in the map file, but
>>>>>> we do not use that many colors right now. (we tried adding the same
>>>>>> color more than one time, but that created other problems....)
>>>>>> I have attached a png file showing the problem across a lake. The
>>>>>> color on the right side is the correct color and the color we have
>>>>>> added to the palette file. The color on the left side of the lake is
>>>>>> not something we have set.
>>>>>> I have also added the palette.txt file and the outputformat we use is
>>>>>> this:
>>>>>> OUTPUTFORMAT
>>>>>> NAME "png"
>>>>>> DRIVER "AGG/PNG"
>>>>>> IMAGEMODE "rgb"
>>>>>> EXTENSION "png"
>>>>>> END
>>>>>> Does anybody know why this happens in Mapserver and how to fix it?
>>>>>> Espen
>>>>> _______________________________________________
>>>>> mapserver-users mailing list
>>>>> mapserver-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
