[mapserver-users] SUA convert
    Scott Penrose
    scottp at dd.com.au
    Mon Nov  9 04:06:09 PST 2009
Hey team
I am using Mapserver to show some airspace, and the data comes in a
standard format called SUA or OpenAir. Both a basic text files using
LatLong and descriptives shapes, such as:
TYPE=CTA/CTR
TITLE=ADELAIDE
TOPS=FL245
BASE=FL180
POINT=S353001 E1364920
POINT=S351526 E1373454
ANTI-CLOCKWISE RADIUS=49.97 CENTRE=S345649 E1383128 TO=S354540 E1381803
POINT=S354540 E1381803
POINT=S362422 E1380512
ANTI-CLOCKWISE RADIUS=89.95 CENTRE=S345649 E1383128 TO=S353001 E1364920
What would be the best (probably read here - easiest) way to display
the data on mapserver?
Which probably translates to - what is the easiest file format or
tools to use to convert and display the data above?
E.g. I could write some Perl/XSL to convert the files into KML - but
is that the right format? Perhaps shape files?
Or... hope above hope... maybe someone has done this already? or knows
another way to show Airspace files?
Thanks
Scott
More information about the MapServer-users
