[mapserver-users] entities one upon the other
Dan Little
danlittle at yahoo.com
Thu Nov 12 10:09:02 EST 2009
You have a few options based on what you know about ahead of time:
1) If you know the stacking order ahead of time you can create separate layers that force the stacking to happen properly.
2) If you don't know the stacking order ahead of time, you can try using patterned fills instead of opaque fills.
From: Leonardo Olivieri <leonardo.olivieri at imteam.it>
To: mapserver-users at lists.osgeo.org
Sent: Thu, November 12, 2009 8:32:40 AM
Subject: [mapserver-users] entities one upon the other
Hello,
I have a polygon layer with entities, one located upon the other.
The result that I have is:
The entity located upon, hides the entity underneath.
Is it possible to configure mapfile in such a way that where the
entities are located ones upon the others,
the colour becomes evidenced and different to the case in which the
entities aren't located ones upon the others?
Thank in advance
Leonardo
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091112/cb58dec1/attachment.html
