[mapserver-users] entities one upon the other
Thomas Bonfort
thomas.bonfort at camptocamp.com
Fri Nov 13 03:07:03 EST 2009
if you're using the AGG rendering backend, you can set an opacity on
your polygon styles, in which case you should see varying opacity the
more features are piled one upon another.
STYLE
COLOR r g b
OPACITY 50
END
regards,
thomas
www.camptocamp.com
+33 5 16 57 01 02
On Thu, Nov 12, 2009 at 15:32, Leonardo Olivieri
<leonardo.olivieri at imteam.it> wrote:
> Hello,
> I have a polygon layer with entities, one located upon the other.
> The result that I have is:
> The entity located upon, hides the entity underneath.
> Is it possible to configure mapfile in such a way that where the
> entities are located ones upon the others,
> the colour becomes evidenced and different to the case in which the
> entities aren't located ones upon the others?
> Thank in advance
> Leonardo
> mapserver-users at lists.osgeo.org
