[mapserver-users] performance problem with ortho images
Liang Jian
Liang.Jian at eniro.com
Mon Nov 16 06:02:25 EST 2009
Hi all,
I have a problem with mapserver handling ortho images. The situation is we have 2m data cover the whole country and 20-50cm data cover most cities. We setup mapfiles as 2m data shows between scale 200k to 500 and 20-50cm data show between scale 100k to 500. Problem is when requirst data in the city ranges, mapserver first read data from 20-50cm dataset and then read from 2m dataset which is unnecessary as the 20-50cm data is enough and the best solution is when there is no 20-50cm data, 2m data should be used instead.
Do you have any idea how to avoid the unnecessary reading?
Any suggestions will be welcome!
Thanks
/Liang
Confidentiality Notice: This e-mail transmission may contain confidential or legally privileged information that is intended only
for the individual or entity named in the e-mail address. If you are not the intended recipient, you are hereby notified that any
disclosure, copying, distribution, or reliance upon the contents of this e-mail is strictly prohibited and may be unlawful. If you have received this e-mail in error, please notify the sender immediately by return e-mail and delete all copies of this message.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091116/f02bd7ca/attachment.html
