[mapserver-users] Can I set default format for WMS GetFeatureInfo?
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Mon Nov 16 08:18:21 EST 2009
Hi Bart,
I have it set but unfortunately it does not make
"application/vnd.ogc.gml" as default, at least not with this 5.2.1.
-Jukka-
bartvde wrote:
> Hi Jukka,
> it should be possible using:
> wms_feature_info_mime_type
> Best regards,
> Bart
> > Hi,
> > There are stupid WMS clients which can send GetFeatureInfo requests
> > but which do not allow giving INFO_FORMAT parameter. Is
> there a way
> > to configure MapServer to use for example
> > a default info format instead of text/plain if INFO_FORMAT
> parameter
> > is missing from the request?
> > By the way, I noticed that just adding &INFO_FORMAT without an "="
> > sign or info format value is changing the output from text to gml.
> > I am running Mapserver 5.2.1.
> > -Jukka Rahkonen-
> > mapserver-users mailing list
> > mapserver-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
