[mapserver-users] MapServer, WFS and Oracle
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Wed Nov 18 07:46:56 EST 2009
If you haven't done it yet, check that you can for sure get some data out of your service.
mapserv.exe?map=address.map&typename=address&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&MaxFeatures=10
If yes, have a look at the returned data and see what kind of coordinates it likes to send you. Just to be sure that your BBOX is correct. Also, add DEBUG=5 to the layer definitions and look at the Mapserver errorfile to understand more about what is happening.
-Jukka-
> -----Alkuperäinen viesti-----
> Lähettäjä: Jelmer Baas [mailto:Baas at speerit.nl]
> Lähetetty: 18. marraskuuta 2009 14:39
> Vastaanottaja: Rahkonen Jukka; mapserver-users at lists.osgeo.org
> Aihe: RE: [mapserver-users] MapServer, WFS and Oracle
> Bart, Jukka,
> The shoes taste wonderful. The request comes from OpenLayers,
> and I can't find how to change it to WFS 1.1, but that'll be
> another Google search, soon. Right now I thought it'd be
> smart to see if I at least can get *some* results, manually.
> This however also fails.
> My current request
> ON=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A28992&BBOX=125474.00000
0,381967.999850,206652.000100,470382.335300
> The coordinates come from a previous request (gml:boundedBy)
> and should definatly contain some points. An select count(id)
> from address where x > 125474 and y > 206652 and x < 381967
> and y < 470382 returns 24002 rows (the geo object is also
> saved as plain X/Y).
> For completeness, here's my current MAP file:
> MAP
> NAME Test
> STATUS ON
> UNITS meters
> FONTSET "fontset.txt"
> OUTPUTFORMAT
> NAME aggpng24
> DRIVER AGG/PNG
> TRANSPARENT ON
> IMAGEMODE RGBA
> MIMETYPE "image/png"
> EXTENSION "png"
> END
> WEB
> METADATA
> "wms_title" "Test"
> "wfs_title" "Test"
> "wms_srs" "EPSG:28992 "
> "wfs_srs" "EPSG:28992 "
> "wms_onlineresource" "<url>"
> "wfs_onlineresource" "<url>"
> END # METADATA
> END #web
> SYMBOLSET "symbols_mapinfo2.sym"
> PROJECTION
> "init=epsg:28992"
> END
> LAYER
> NAME address
> TYPE point
> CONNECTIONTYPE oraclespatial
> DATA "GEOLOC FROM ADDRESS USING SRID 90112 VERSION 10g"
> CONNECTION "x/y/z"
> DUMP TRUE
> PROCESSING "CLOSE_CONNECTION=DEFER"
> CLASS
> SYMBOL "circle"
> OUTLINECOLOR 255 0 0
> SIZE 6
> NAME "address"
> END
> PROJECTION
> "init=epsg:28992"
> END
> METADATA
> "wfs_title" "address"
> "wfs_srs" "EPSG:28992"
> "wms_title" "address"
> "wms_srs" "EPSG:28992"
> "gml_featureid" "ZIPCODE"
> "gml_include_items" "ZIPCODE"
> END
> END
> END # Map File
> As you can see, I use the Dutch projection system everywhere.
> Yet the request only returns:
> <?xml version='1.0' encoding="ISO-8859-1" ?> <wfs:FeatureCollection
> xmlns:ms="http://mapserver.gis.umn.edu/mapserver"
> xmlns:wfs="http://www.opengis.net/wfs"
> xmlns:gml="http://www.opengis.net/gml"
> xmlns:ogc="http://www.opengis.net/ogc"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xsi:schemaLocation="http://www.opengis.net/wfs
> http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd
> <url>/mapserv.exe?map=address.map&SERVICE=WFS&VERSION=
> 1.0.0&REQUEST=DescribeFeatureType&TYPENAME=address&
> ;OUTPUTFORMAT=XMLSCHEMA">
> <gml:boundedBy>
> <gml:Box srsName="EPSG:28992">
> <gml:coordinates>125474.000000,381967.999850
> 206652.000100,470382.335300</gml:coordinates>
> </gml:Box>
> </gml:boundedBy>
> </wfs:FeatureCollection>
> Any more help would be greatly appreciated.
> Regards,
> Jelmer
> > Hi,
> > I hope you have tasty shoes. WFS 1.0.0 does officially
> support only
> > one projection. I am not sure how Marverver has implemented
> it, with
> > Geoserver it is possible to use also other projections by adding
> > projection parameter to request.
> > However, I would try GetFeature request by using BBOX in native
> > projection.
> > -Jukka Rahkonen-
> > > Lähettäjä: mapserver-users-bounces at lists.osgeo.org
> > > [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta
> > Jelmer Baas
> > > Lähetetty: 18. marraskuuta 2009 13:06
> > > Jukka,
> > > Thanks for the quick reply. The request is:
> > > ON=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=1.17194606291
> > 7749,52.038473357169345,5.173921509856943,52.03887593415947
> > > (Very zoomed out)
> > > If this is another projection issue, I'm going to eat my shoe. ;)
> > > Regards,
> > > Jelmer
> > > > -----Original Message-----
> > > > From: Rahkonen Jukka [mailto:Jukka.Rahkonen at mmmtike.fi]
> > > > Sent: woensdag 18 november 2009 11:51
> > > > To: Jelmer Baas; mapserver-users at lists.osgeo.org
> > > > Subject: Re: [mapserver-users] MapServer, WFS and Oracle
> > > > Hi,
> > > > You seem not to get even a single feature back, all you
> get is an
> > > > empty bounding box. How does you GetFeature request look like?
> > > > -Jukka Rahkonen-
> > > > Jelmer Baas
> > > > > Lähetetty: 18. marraskuuta 2009 12:11
> > > > > Vastaanottaja: mapserver-users at lists.osgeo.org
> > > > > Aihe: [mapserver-users] MapServer, WFS and Oracle
> > > > > Hello list,
> > > > > I'm trying to get MapServer running as a WFS server with
> > > an Oracle
> > > > > data source. When using TAB files I have no problem, also
> > > using the
> > > > > Oracle datasource and letting MapServer draw it (WMS) works
> > > > > properly.
> > > > > However, the WFS request only returns one result (a
> > > correct one). My
> > > > > total resulting XML is:
> > > > > http://x.x.x/scripts/mapserv.exe?map=address.map&SERVICE=WFS&V
> > > > > ERSION=1.0
> > > > > .0&REQUEST=DescribeFeatureType&TYPENAME=address&OUTPUTFORMAT=X
> > > > > MLSCHEMA">
> > > > > <gml:boundedBy>
> > > > > <gml:Box srsName="EPSG:4326">
> > > > > <gml:coordinates>5.172200,52.038485
> > > > > 5.173701,52.038853</gml:coordinates>
> > > > > </gml:Box>
> > > > > </gml:boundedBy>
> > > > > There should be more results (confirmed by the WMS
> image and by
> > > > > monitoring the query in Oracle). I also set DUMP to true and
> > > > > "gml_include_items" "all" in my layer METADATA, so I also
> > > expected
> > > > > more fields. My layer definition is as follows:
> > > > > LAYER
> > > > > NAME address
> > > > > TYPE point
> > 90112 VERSION 10g"
> > > > > CONNECTION "x/y at z"
> > > > > DUMP TRUE
> > > > > CLASS
> > > > > SYMBOL "circle"
> > > > > SIZE 6
> > > > > NAME "address"
> > > > > END
> > > > > PROJECTION
> > > > > "init=epsg:28992"
> > > > > END
> > > > > METADATA
> > > > > "wfs_srs" "EPSG:28992 EPSG:900913"
> > > > > "wms_srs" "EPSG:28992 EPSG:900913"
> > > > > "gml_featureid" "ID"
> > > > > END
> > > > > END
> > > > > Any idea what I'm doing wrong? I'm using MapServer 5.4.2
> > > with Oracle
> > > > > 10g.
> > > > > Regards,
> > > > > Jelmer Baas
> > > > > _______________________________________________
> > > > > mapserver-users mailing list
> > > > > http://lists.osgeo.org/mailman/listinfo/mapserver-users
