[mapserver-users] fatal error on linux server
    Jelmer Baas
    Baas at speerit.nl
    Wed Nov 18 06:15:53 PST 2009
Might I also suggest checking if the .shp file is in the correct case?
KB_ACEH is uppercase, while .shp is lowercase, I've had plenty of
problems (i.e., typo's) with that.
Regards,
Jelmer
> As Francesco indicated, the primary error in this case is
> that the file
> /home/bleketux/public_html/cmh2/mapserver/shp/KB_ACEH.shp
> cannot be opened.
> Make sure the file exists at that location, and that it is
> readable by
> the user running the Apache. hint: check the permissions on
> /home/bleketux
> Daniel
> francesco wrote:
> > Should check your mapfile if it is correctly parsed by the
> mapscritpt.
> > Try drawing the mapfile using standard mapserver.exe and
> see if it works.
> > Francesco Pirotti
> > MSulchan Darmawan ha scritto:
> >> Dear all,
> >> I've made a PHP script and tried it on windows using ms4w
> (mapserver
> >> 5.4.2) and it's completely works.
> >> Then I tried it on linux (ubuntu server 8.04 with
> mapserver 5.4.2) but
> >> it produce the following error :
> >> Warning: [MapServer Error]: msDrawMap(): Failed to draw layer named
> >> 'aceh'.
> >> in
> /home/bleketux/public_html/cmh2/_modules/mod_petazm/frm_petazm.php
> >> on line 184
> >> Warning: [MapServer Error]: msShapefileOpen(): (KB_ACEH.shp)
> >> in
> >> on line 184
> >> (/home/bleketux/public_html/cmh2/mapserver/shp/KB_ACEH.shp)
> >> in
> >> on line 184
> >> Fatal error: Call to a member function SaveWebImage() on a
> non-object
> >> in
> >> on line 185
> >> Here is some script of line 180 - 185 :
> >> $strProj = "proj=latlong,ellps=WGS84,datum=WGS84";
> >> $objMap->SetProjection ($strProj, MS_FALSE);
> >> $objMap->outputformat->Set ("name", "Format GIF");
> >> $objMap->outputformat->Set ("extension", "gif");
> >> $objImagePeta = $objMap->Draw();
> >> $objUrlPeta     = $objImagePeta->SaveWebImage();
> >> To avoid permission problem, i've set chmod 777 to the
> root web folder.
> >> Can you point me where should I fix the problem ?
> >> Thanks in advance.
More information about the MapServer-users
