[mapserver-users] template not showing map
Fawcett, David (MPCA)
David.Fawcett at state.mn.us
Wed Nov 18 16:04:29 EST 2009
As an aside for the doc gods...
On http://mapserver.org/mapfile/web.html, shouldn't it say:
IMAGEURL [url]
Base URL for IMAGEPATH. This is the URL that will take the web browser to IMAGEPATH to get the images.
And not:
IMAGEURL [path]
And maybe mention that the URL should be relative to the Web root?
David.
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Bryan Hempen
Sent: Wednesday, November 18, 2009 2:53 PM
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] template not showing map
Fawcett, David (MPCA) schrieb:
> Also, do you have an opening tag for your image? I just see the below line with only a closing tag for img:
> <a
> href='http://www.umn-mapserver-community.de'>http://www.umn-mapserver-community.de</img>
> David.
> Sent: Wednesday, November 18, 2009 1:50 PM
> Subject: [mapserver-users] template not showing map
> Hi there!
> i have a problem diplaying nodes, which are read from a
> postgresql/postgis database.
> specifically the problem is that when trying to display the nodes using
> a pretty standard template i don not get a picture, but surprisingly it
> is generated in the tmp folder (with right timestamp). i am also able to
> show it via web when navigating to the tmp folder, so it might not be a
> problem of user rights.
> http://www.pictureupload.de/originals/pictures/181109204617_no_map_displayed.png
> shows what it looks like when viewing the template
> http://www.pictureupload.de/originals/pictures/181109204754_picture_generated.png
> but the picture is generated!
> Hopefully you guys can help me if i provide you with the mapfile and the
> template-sourcecode.
> please let me know if there is anything more you need me to provide you
> with.
> thanks for the help
> bryan hempen
> # WFS.MAP
> MAP
> NAME 'WFS-Server'
> IMAGETYPE PNG
> EXTENT 8.01 52.2282 8.135 52.3109 #Osm-Koords.
> UNITS METERS
> DEBUG ON
> # SHAPEPATH 'C:/ms4w/Apache/htdocs/osnamap/data'
> SYMBOLSET '/home/sgraeule/public_html/mapserver/symbols/symbols.sym'
> FONTSET '/home/sgraeule/public_html/mapserver/fonts/fonts.list'
> IMAGECOLOR 200 200 200
> SIZE 500 500
> # Grundeinstellungen---------------------------------------------
> PROJECTION
> 'init=epsg:4326'
> END
> WEB
> TEMPLATE '/home/sgraeule/public_html/mapserver/template.html'
> IMAGEPATH '/home/sgraeule/public_html/tmp/'
> IMAGEURL '/tmp/'
> METADATA
> "WFS_TITLE" "WFS-Test"
> "WFS_SRS" "epsg:4326"
> "WFS_ABSTRACT" "POIS"
> "WFS_ONLINERESOURCE"
> "http://igf-project.igf.uni-osnabrueck.de/cgi-bin/mapserv?map=/home/sgraeule/public_html/mapserver/wfs.map"
> END
> END
> LAYER
> SYMBOLSCALE 50000
> NAME 'punkt_db' # Layer-Name, der in OpenLayers aufgerufen
> wird
> TYPE POINT
> STATUS DEFAULT
> CONNECTIONTYPE postgis # Verbindung zur PostGIS-Datenbank
> CONNECTION "user=# password=# dbname=# host=localhost port=5432"
> DATA "geom from nodes"
> CLASSITEM 'id'
> DUMP TRUE
> METADATA
> "WFS_TITLE" "geb"
> "WFS_SRS" "epsg:4326" # Festlegung des Koordinatensystems
> "gml_featureid" "id"
> "GML_INCLUDE_ITEMS" "all"
> END
> CLASS # Stil-Optionen; spielen fuer OpenLayers
> keine Rolle
> STYLE
> SYMBOL 'circle'
> SIZE 9
> MINSIZE 9
> MAXSIZE 15
> COLOR 0 0 200
> END
> END
> END
> END
> <!-- MapServer Template -->
> <html>
> <head>
> <title>Beispiel zum UMN MapServer</title>
> </head>
> <body font face="VERDANA,ARIAL,HELVETICA">
> <b>Beispiel: UMN MapServer</b><br>
> <a
> <br>
> <a
> href="/cgi-bin/mapserv?map=/home/sgraeule/public_html/mapserver/wfs.map">Ausgangszustand</a>
> <form method="GET" action="/cgi-bin/mapserv">
> <table>
> <tr>
> <td valign="top">
> <input type="image" name="img" src="[img]" border="1">
> <br>
> </td>
> <input type="hidden" name="map" value="[map]"> <!-- Pfad zur map-Datei -->
> <input type="hidden" name="imgext" value="[mapext]"> <!--
> Kartenausdehnung -->
> <input type="hidden" name="imgxy" value="190 190"> <!-- das mittlere
> Pixel der Grafik (dient als Zentrum beim Zoomen) -->
> <td valign="top">
> <br><br>
> <b>Möchten Sie "Browsen" oder eine Abfrage durchführen?</b><br>
> <input type="radio" name="mode" value="browse"
> checked>Browse</input><br>
> value="query">Abfrage</input><br><br><br>
> Zoom<br>
> <select name="zoom" size="1">
> <option value="4">4X hinein</option>
> <option value="2">2X hinein</option>
> <option value="1" selected>nein</option>
> <option value="-2">2X heraus</option>
> <option value="-4">4X heraus</option>
> </select><br>
> </form>
> </td>
> </tr>
> <table>
> <!-- <img src="[legend]"> -->
> </body>
> </html>
hi!
imagepath + imageurl are definately set right now, but it does not
change anything.
IMAGEPATH '/home/sgraeule/public_html/mapserver/tmp/'
IMAGEURL '/home/sgraeule/public_html/mapserver/tmp/'
you may want to take a look by yourself:
http://igf-project.igf.uni-osnabrueck.de/~sgraeule/mapserver/tmp/
i am not sure about how to use the image-tag, so i added the following
piece of code to the template.
<img src="[img]"> </img>
when executed umn mapserver correctly makes it <img
src="/home/sgraeule/public_html/mapserver/tmp/WFS-Server12585768438242.png">
</img>
,but my firefox still does not show the picture, but just a hint that
there should be a picture which was not found...
bryan
