[mapserver-users] Problem with a GetFeatureInfo - info_format	=	text/html
    Daniel Morissette
    dmorissette at mapgears.com
    Wed Nov 18 13:43:52 PST 2009
Martin Ouellet wrote:
> Hi,
> I've got the current layer definition
> TEMPLATE "http://geomsp.msp.gouv.qc.ca/communs/todo2.html"
> I receive this response:
> [DATE_PRODUCTION] -> mapserver dont seem to replace the variable with
> the query value
When you specify a URL in the TEMPLATE parameter, then the parameters
replacement is done in the URL itself, and MapServer will redirect the
client to the URL in which the variable replacements have been made e.g.
TEMPLATE
"http://geomsp.msp.gouv.qc.ca/communs/todo2.html?DATEPROD=[DATE_PRODUCTION]"
To use a regular template file, you need to specify its path on disk,
and then MapServer will load the template and do the variable
replacements inside the template. e.g.
TEMPLATE "/path/to/communs/todo2.html"
Daniel
Daniel Morissette
http://www.mapgears.com/
More information about the MapServer-users
