[mapserver-users] PHP mapscript $shape->buffer() takes alongtime
    Worth Lutz
    wal3 at mindspring.com
    Wed Nov 18 14:30:16 PST 2009
I need the buffered shape to draw it.  Once I have it does it make any
difference is how I do the query?
Is the enhancement described in Ticket #2753 implemented in 5.6 for PHP
mapscript?  Or will I need to take my shape to postGIS to simplify before
buffer?
-----Original Message-----
From: Steve Lime [mailto:Steve.Lime at dnr.state.mn.us]
Sent: Wednesday, November 18, 2009 9:35 AM
To: ludwig at kni-online.de; mapserver-users at lists.osgeo.org;
Subject: RE: [mapserver-users] PHP mapscript $shape->buffer() takes
alongtime
You may not need to buffer at all. The shape query honors layer tolerances
so
you can find parcels within a certain distance. So if $layer->{tolerance} is
500
and $layer->{toleranceunits} is 'meters' then your shape query will find all
features within 500 meters. If you don't need to draw the buffered shape
then
this might be a good option.
Steve
>>> "Worth Lutz" <wal3 at mindspring.com> 11/18/09 8:23 AM >>>
I'm learning a lot here.
I now understand how to get the buffered geometry quickly.
I am using the buffered geometry to use PHP mapscript to select parcel
intersecting the buffered geometry.
$layer->queryByShape($bufferedShape);
Are you telling me that there is a better/faster way to do this?
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Ludwig
Kniprath
Sent: Wednesday, November 18, 2009 3:01 AM
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] PHP mapscript $shape->buffer() takes a
longtime
We had the same problem. In deed the buffer-algorithm is very expensive,
especially with large polygons and a large buffer-radius. If you use
Postgis, you can simplify the Polygon with ST_Simplify or
ST_SimplifyPreserveTopology in dependency from scale and buffer-radius, this
will make the buffer-process much faster without significant loss of
quality. You can do this on runtime on your original data with dynamic
PostGIS-queries. If you don't use PostGis, you have to create simplified
layers.
Pseudo-PHP-PostGIS-SQL:
SELECT ...
ST_SetSRID(ST_BUFFER(ST_SIMPLIFY($geometery_field,$simplify_tolerance),$buff
er_radius, $number_of_segments),$srid)::geometry ...FROM...
And don't use the buffered polygon for geo-queries, there are faster ways in
PostGIS and Mapserver.
Regards
Ludwig Kniprath
>I'm trying to buffer a shape returned from a point query on a polygon layer
>of parcels.
>When I try to use:
>$bufferedShape = $shape->buffer(200);
>I get back a fatal error: Maximum execution time of 30 seconds exceeded.
>I know that this is a php error message and that I could increase the
>allowable execution time.
>If I use a buffer distance of 175 I get results.
>Should it take such a long time to but a buffer around this parcel?  It is
a
>large parcel with one corner being a long curve like a quarter of a circle
>and another section on one side being a half circle.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users
