[mapserver-users] Usage of Vendor Option
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Nov 23 10:47:09 EST 2009
David,
Try using
"labelcache_map_edge_buffer" "-10" at map level WEB METADATA
PROCESSING "LABEL_NO_CLIP=ON" at layer level
Partials=true with labels
-Steve W.
David Alda Fernandez de Lezea wrote:
> Hello,
> Thanks for your response. Just to clarify I've just added the comments bellow:
>>From a quick test I did locally using latest MapServer, I don;t see any particular issues with your sld. I was able to generate the labels as expected.
> I'm also able to generate the labels, but the problem is that some of them are cut and thay are also repeated over the polygon. See attached file.
>> Note that the anchor position is only used when labeling point features.
> I thought it could be possible to add a label in the centroid of the polygon, and just one label.
>> Are each polygon formed with one shape or could one polygon be formed by several adjacent shapes?
> I don't understand what you mean here. I'm using Oracle Spatial as DataSource and my layer is a polygon table.
>> You can also check the log files and see what your layer looks like after the sld is applied: add something like this in your map file for example:
>> CONFIG "MS_ERRORFILE" "f:/logs/my_log_file.log"
>> DEBUG 5
> Here is what I get from the log file
> [Mon Nov 23 08:54:37 2009].387000 msApplySLD(): Map file after SLD was applied C:/ms4w/Apache/htdocs/MFD/tmp/4b0a3fbd_1058_1._sld.map[Mon Nov 23 08:54:37 2009].512000 msDrawMap(): Layer 5 (municipios), 0.093s
> [Mon Nov 23 08:54:37 2009].512000 msDrawMap(): Drawing Label Cache, 0.000s
> [Mon Nov 23 08:54:37 2009].512000 msDrawMap() total time: 0.093s
> [Mon Nov 23 08:54:37 2009].528000 msSaveImage() total time: 0.016s
> [Mon Nov 23 08:54:37 2009].528000 mapserv request processing time (msLoadMap not incl.): 0.172s
> [Mon Nov 23 08:54:37 2009].528000 msFreeMap(): freeing map at 015968D8.
> An then I go to the file referenced in the log and I see a mapfile with the following lines, but I don't know what exaclty do I have to find...
> MAP
> EXTENT 460000 4708766.29018245 610000 4821233.70981755
> FONTSET "misc/fonts/fonts.txt"
> IMAGECOLOR 255 255 255
> IMAGETYPE png24
> SYMBOLSET "misc/symbols/symbols.sym"
> SHAPEPATH "shapes/"
> SIZE 1152 864
> STATUS ON
> UNITS METERS
> CONFIG MS_ERRORFILE "C:/ms4w/Apache/htdocs/MFD/tmp/ms_wms.log"
> NAME "WMSSERVER"
> DEBUG 5
> OUTPUTFORMAT
> NAME "png24"
> MIMETYPE "image/png; mode=24bit"
> DRIVER "GD/PNG"
> EXTENSION "png"
> IMAGEMODE "RGB"
> TRANSPARENT FALSE
> END
> OUTPUTFORMAT
> NAME "png"
> MIMETYPE "image/png"
> DRIVER "AGG/PNG"
> EXTENSION "png"
> IMAGEMODE "RGBA"
> TRANSPARENT TRUE
> FORMATOPTION "TRANSPARENT=ON"
> FORMATOPTION "INTERLACE=OFF"
> END
> SYMBOL
> NAME "sld_line_symbol"
> TYPE ELLIPSE
> FILLED TRUE
> POINTS
> 1 1
> END
> END
> PROJECTION
> "init=epsg:23030"
> END
> LEGEND
> KEYSIZE 20 10
> KEYSPACING 5 5
> LABEL
> SIZE MEDIUM
> TYPE BITMAP
> BUFFER 0
> COLOR 0 0 0
> FORCE FALSE
> MINDISTANCE -1
> MINFEATURESIZE -1
> OFFSET 0 0
> PARTIALS TRUE
> END
> POSITION LL
> STATUS OFF
> END
> QUERYMAP
> COLOR 255 255 0
> SIZE -1 -1
> STATUS OFF
> STYLE HILITE
> END
> SCALEBAR
> ALIGN CENTER
> COLOR 0 0 0
> INTERVALS 4
> LABEL
> SIZE MEDIUM
> TYPE BITMAP
> BUFFER 0
> COLOR 0 0 0
> FORCE FALSE
> MINDISTANCE -1
> MINFEATURESIZE -1
> OFFSET 0 0
> PARTIALS TRUE
> END
> POSITION LL
> SIZE 200 3
> STATUS OFF
> STYLE 0
> UNITS MILES
> END
> WEB
> IMAGEPATH "C:/ms4w/Apache/htdocs/MFD/tmp/"
> IMAGEURL "tmp/"
> METADATA
> "wms_srs" "EPSG:23030 EPSG:4326"
> "wms_onlineresource" "http://192.168.1.65/cgi-bin/mapserv.exe?map=../htdocs/MFD/ejemplo_wms.map&"
> "wms_abstract" "Servicio de mapas WMS de IKT Nekazal Teknologia. Powered by Apache and UMN MapServer"
> "wms_transparent" "true"
> "wms_name" "IKT WMS Server"
> "wms_feature_info_mime_type" "application/vnd.ogc.gml"
> "wms_keywordlist" "IKT,Euskadi,Mapas Euskadi"
> "wms_title" "Servidor WMS IKT"
> END
> QUERYFORMAT text/html
> LEGENDFORMAT text/html
> BROWSEFORMAT text/html
> END
> LAYER
> CONNECTION "XXXX/XXXX at XXXXX"
> CONNECTIONTYPE ORACLESPATIAL
> DATA "GEOMETRY FROM (SELECT * FROM GT_MUNICIPIOS_96) USING UNIQUE gid SRID 82337"
> DUMP TRUE
> METADATA
> "wms_srs" "EPSG:23030"
> "wms_extent" "460000 4710000 610000 4820000"
> "wms_name" "municipios"
> "wms_format" "image/png"
> "gml_include_items" "all"
> "wms_server_version" "1.1.1"
> "wms_title" "municipios 96"
> END
> NAME "municipios"
> PROJECTION
> "init=epsg:23030"
> END
> STATUS ON
> TYPE POLYGON
> UNITS METERS
> CLASS
> NAME "Unknown"
> LABEL
> SIZE MEDIUM
> TYPE BITMAP
> BUFFER 0
> COLOR 0 0 0
> FORCE FALSE
> MINDISTANCE -1
> MINFEATURESIZE -1
> OFFSET 0 0
> OUTLINECOLOR 255 255 255
> OUTLINEWIDTH 0
> PARTIALS TRUE
> POSITION CC
> END
> MAXSCALEDENOM 65000
> MINSCALEDENOM 30000
> STYLE
> ANGLE 360
> COLOR 102 166 30
> OPACITY 55
> SYMBOL 0
> END
> STYLE
> ANGLE 360
> OPACITY 100
> OUTLINECOLOR 0 234 0
> SIZE 2
> SYMBOL "sld_line_symbol"
> END
> TEXT ([MUNICIPIO])
> END
> END
> END
> Thanks. Hope you can help me.
> Un saludo,
> David Alda Fernández de Lezea
> Lurralde eta Biodibertsitate Saila / Dpto. de Territorio y Biodiversidad
> IKT
> Granja Modelo s/n · 01192 · Arkaute (Araba)
> Tlfnos.: 945-00-32-95 Fax: 945-00.32.90
> email: dalda at ikt.es web: www.ikt.es
> -----Mensaje original-----
> De: Yewondwossen Assefa [mailto:yassefa at dmsolutions.ca]
> Enviado el: viernes, 20 de noviembre de 2009 15:00
> Para: David Alda Fernandez de Lezea
> CC: mapserver-users at lists.osgeo.org
> Asunto: Re: [mapserver-users] Usage of Vendor Option
> David,
> From a quick test I did locally using latest MapServer, I don;t see any particular issues with your sld. I was able to generate the labels as expected. Note that the anchor position is only used when labeling point features.
> Are each polygon formed with one shape or could one polygon be formed by several adjacent shapes? You can also check the log files and see what your layer looks like after the sld is applied: add something like this in your map file for example:
> DEBUG 5
> regards,
>> Hi,
>> I've got a SLD that I apply to a polygon layer and I want to add a
>> label to identify those polygons. I manage to add the the labels but
>> my problem is that the labels are repeated a lot of times into the
>> polygons and furthermore they don't appear on the centroif of my
>> polygon. Here is my TextSymbolizer tag:
>> <TextSymbolizer>
>> <sld:MinScaleDenominator>3000</sld:MinScaleDenominator>
>> <sld:MaxScaleDenominator>5000</sld:MaxScaleDenominator>
>> <Label>
>> <ogc:PropertyName>MUNICIPIO</ogc:PropertyName>
>> </Label>
>> <Font>
>> <CssParameter name="font-family">Arial</CssParameter>
>> <CssParameter name="font-weight">bold</CssParameter>
>> <CssParameter name="font-size">8</CssParameter>
>> </Font>
>> <!-- this centers the label on the polygon's centroid-->
>> <LabelPlacement>
>> <PointPlacement>
>> <AnchorPoint>
>> <AnchorPointX>0.5</AnchorPointX>
>> <AnchorPointY>0.5</AnchorPointY>
>> </AnchorPoint>
>> </PointPlacement>
>> </LabelPlacement>
>> <!-- make the label easy to read-->
>> <Halo>
>> <Radius>
>> <ogc:Literal>2</ogc:Literal>
>> </Radius>
>> <Fill>
>> <CssParameter name="fill">#FFFFFF</CssParameter>
>> <CssParameter name="fill-opacity">0.85</CssParameter>
>> </Fill>
>> </Halo>
>> <Fill>
>> <CssParameter name="fill">#000000</CssParameter>
>> </Fill>
>> <!-- This labels each name only once, not every shape with
>> that name -->
>> <VendorOption name="group">true</VendorOption>
>> </TextSymbolizer>
>> Un saludo,
>> *David Alda Fernández de Lezea*
>> Biodiversidad
>> *IKT*
>> <mailto:dalda at ikt.es> web: www.ikt.es
>> <http://www.ikt.es/>
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Assefa Yewondwossen
> Software Analyst
> Email: assefa at dmsolutions.ca
> http://www.dmsolutions.ca/
> Phone: (613) 565-5056 (ext 14)
> Fax: (613) 565-0925
