[mapserver-users] php-mapscript compilation problem on OpenSuse
11.1/11.2
Martin Ouellet
geomartino at gmail.com
Mon Nov 23 11:57:42 EST 2009
Even with the mapserv-5.6-beta5, there's still no php_mapscript.so after the
compilation. I notice one thing, the directory
"/usr/include/php5/dl" (which I see appear while the make command is
running) is missing on my server.
Could it be the problem?.
Here's my ./configure command:
configure: checking for PHP/MapScript module options...
user disabled shared library support.
checking for location of config.h or php_config.h...
/usr/include/php5/main/php_config.h
checking whether we have PHP3 or PHP4... -DPHP4
checking whether we should use PHP's regex... yes
found regex.h - building PHP MapScript with PHP's bundled regex
PHP/MapScript module configured.
checking if --enable-runpath requested... no
checking if --with-java-include-os-name specified... no, autodetected
linux
configure: creating ./config.status
config.status: creating Makefile
config.status: creating mapscript/php3/Makefile
config.status: creating mapscript/java/Makefile
config.status: creating mapscript/csharp/Makefile
MapServer is now configured for
-------------- Compiler Info -------------
C compiler: gcc -g -fPIC -Wall
C++ compiler: g++ -g -fPIC -Wall
Debug: -g
Generic NINT:
-------------- Renderer Settings ---------
OpenGL support:
zlib support: -DUSE_ZLIB
png support:
palette rgba png support:
jpeg support:
iconv support: -DUSE_ICONV
AGG support: -DUSE_AGG
Cairo (SVG,PDF) support:
Ming(flash) support:
PDFLib support:
-------------- Support Libraries ---------
Proj.4 support: -DUSE_PROJ
Libxml2 support:
FriBidi support:
Curl support: -DUSE_CURL
FastCGI support:
Threading support: -DUSE_THREAD
GEOS support:
-------------- Data Format Drivers -------
native tiff support:
PostGIS support: -DUSE_POSTGIS
EPPL7 support: -DUSE_EPPL
ArcSDE support:
OGR support:
GDAL support: -DUSE_GDAL
Oracle Spatial support: -DUSE_ORACLESPATIAL
-------------- OGC Services --------------
WMS Server: -DUSE_WMS_SVR
WMS Client: -DUSE_WMS_LYR
WFS Server:
WFS Client: -DUSE_WMS_LYR
WCS Server:
SOS Server:
-------------- MapScript -----------------
PHP MapScript: yes
2009/11/20 Daniel Morissette <dmorissette at mapgears.com>
> Martin Ouellet wrote:
>> We are unable to build php_mapscript.so. We know that it's possible
>> because someone maintain a php-mapserv package for
>> opensuse. We look in the needed of the package and everything seem to be
>> there.
>> Does someone have an idea why my php_mapscript.so doesn't build ?
> php_mapscript.c: In function ‘php3_ms_img_pasteImage’:
>> php_mapscript.c:6596: warning: implicit declaration of function
>> ‘php_gd_gdImageColorExact’
>> php_mapscript.c:6600: warning: implicit declaration of function
>> ‘php_gd_gdImageColorTransparent’
>> php_mapscript.c:6603: warning: implicit declaration of function
>> ‘php_gd_gdImageCopy’
> Sounds like you bumped into the issue behind ticket #3117 which is fixed in
> the upcoming 5.6 release.
> You could either use the latest 5.6-beta5 source which includes the fix, or
> apply the patch to your local source tree. See
> http://trac.osgeo.org/mapserver/ticket/3117#comment:7
> Daniel
> Daniel Morissette
> http://www.mapgears.com/
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091123/5ccc0697/attachment-0001.html
