[mapserver-users] Export SVG
Yewondwossen Assefa
yassefa at dmsolutions.ca
Wed Nov 25 18:39:26 EST 2009
Not sure I get it correctly: MapServer exports a vector file (the svg),
when you mention anti-aliasing, I believe you are referring to an svg
viewer rendering the svg file? From what I understand, the svg
specifications allows to specify some properties at the shape level for
example to give a hint to the viewers on how to render the different
shapes (http://www.w3.org/TR/SVG/painting.html#ShapeRenderingProperty).
Depending on the viewer, I suppose some would respect these properties.
MapServer does not at the point setup these properties. Is this what
you are looking for?
regards.
Maria Neywell wrote:
> Thanks,
> I have already tried this way to extract my map in a svg file and it
> works. _However_, I had a svg file which corresponds to my map but
> with a lot of aliasing. The FORMATOPTION "FULL_RESOLUTION=TRUE"
> changes nothing. I tested this with and without option.
> I don't know if I did something wrong or if this is a mapserver problem…
> am I the only one to have this problem ?
> Regards,
> Maria
> 2009/11/24 Yewondwossen Assefa <yassefa at dmsolutions.ca
> <mailto:yassefa at dmsolutions.ca>>
> Hi,
> You could possibly specify FULL_RESOLUTION option in your
> outputformat. Something like this:
> OUTPUTFORMAT
> NAME svg
> MIMETYPE "image/svg+xml"
> DRIVER svg
> END
> best regards,
> Hi list,
> I'm using mapserver 5.2.
> I have tested all mapserver exports to render my map in svg,
> see : http://mapserver.org/output/svg.html but, the point is
> that all of these outputs give me up simplified geometry. I
> want to export my map in a svg with geometries who match
> exactly with my map.
> did someone noticed that same weird result ?
> Regards,
> Maria
> mapserver-users at lists.osgeo.org
> <mailto:mapserver-users at lists.osgeo.org>
> Assefa Yewondwossen Software Analyst
> Email: assefa at dmsolutions.ca <mailto:assefa at dmsolutions.ca>
> http://www.dmsolutions.ca/
> Phone: (613) 565-5056 (ext 14)
> Fax: (613) 565-0925
Assefa Yewondwossen
Software Analyst
Fax: (613) 565-0925
