[mapserver-users] getLegendGraphic Request error
    Yewondwossen Assefa
    yassefa at dmsolutions.ca
    Thu Nov 26 06:09:26 PST 2009
Hi There,
Boer, dr. W.M. de (Thijs) wrote:
> Hello list,
> wenn I send my getLegendGraphic Request I get the following error:
> [Thu Nov 26 09:44:02 2009].113000 msImageCreateGD(): Image handling error. Cannot create GD image of size 67x-2.
> [Thu Nov 26 09:44:02 2009].113000 msDrawLegend(): GD library error. Unable to initialize image.
> Does anyone know, what can be wrong? How can I solve the problem?
 Would it be possible to make available a map/data and the full
getlegendgraphic url and I can quickly check the case your are facing?
Something is going wrong when calculating the size of the legend or the
icons but could not quickly identify it by looking in the code.
regards
> Greetings,
> Thijs
> Dit bericht kan informatie bevatten die niet voor u is bestemd. Indien u niet de geadresseerde bent of dit bericht abusievelijk aan u is gezonden, wordt u verzocht dat aan de afzender te melden en het bericht te verwijderen. De Staat aanvaardt geen aansprakelijkheid voor schade, van welke aard ook, die verband houdt met risico's verbonden aan het elektronisch verzenden van berichten.
> This message may contain information that is not intended for you. If you are not the addressee or if this message was sent to you by mistake, you are requested to inform the sender and delete the message. The State accepts no liability for damage of any kind resulting from the risks inherent in the electronic transmission of messages.
> mapserver-users at lists.osgeo.org
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
More information about the MapServer-users
