[mapserver-users] Map from .OSM
Even Rouault
even.rouault at mines-paris.org
Thu Nov 26 13:48:00 EST 2009
Stephen Woodbridge a écrit :
> I believe GDAL/OGR (newer versions) has support for SpatialLite.
Yes. GDAL 1.6 has already read support for SpatiaLite DB through the OGR
sqlite driver
GDAL 1.7dev brings write/creation support. It can also make use of
spatial enabled functions when it is linked to libspatialite instead of
libsqlite3.
See http://gdal.org/ogr/drv_sqlite.html for more info.
> -Steve W
> Rahkonen Jukka wrote:
>> Hi,
>> Igor Brejc wrote interesting news today on osm-users mailing list: "
>> I've implemented importing of OSM data into SpatiaLite DB and
>> integrated it successfully with Kosmos map rendering code. SpatiaLite
>> OSM database can be quite fast, but I had to learn a trick or two to
>> reach good performance. I even managed to import the latest UK data
>> into it and it didn't complain too much. I'm planning to release this
>> in Kosmos v3, hopefully sometimes in the spring of 2010."
>> So there should be a SpatiaLite import utility available in the near
>> future. Next question is if Mapserver can render effectively from
>> SpatiaLite.
>> -Jukka Rahkonen-
>>> -----Alkuperäinen viesti----- Lähettäjä:
>>> mapserver-users-bounces at lists.osgeo.org
>>> [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta Milo van
>>> der Linden Lähetetty: 26. marraskuuta 2009 8:19 Vastaanottaja: abul
>>> khayer Kopio: mapserver-users at lists.osgeo.org Aihe: Re:
>>> Mapserver cannot read osm directly. That is also because there is
>>> no OGR adapter(yet) for .osm.
>>> If you really don't want to set up postgis:
>>> http://wiki.openstreetmap.org/wiki/Category:OSM_processing
>>> You can browse throug a variety of export/conversion tools. One
>>> might just create the format you need (shp). You can also consider
>>> downloading ready-made shapefiles from the websites:
>>> http://www.cloudmade.com
>>> or
>>> http://www.geofabrik.de
>>> Kind regards,
>>> Milo van der Linden (Miblon) Moblin powered asus eee pc 1005HA-H
>>> http://www.dogodigi.net
>>> On Wed, 2009-11-25 at 19:01 -0800, abul khayer wrote:
>>>> Can Mapserver render map from .OSM(Open street map) file
>>>> directly?
>>>> I want to use mapserserver and Openlayer to render a map of .OSM.
>>>> Though i get some help from below tutorial,
>>>> http://trac.osgeo.org/mapserver/wiki/RenderingOsmData But it use
>>>> postgis and there need conversion.
>>>> ....................................... Md. Abul Khayer GIS
>>>> Programmer CEGIS (www.cegisbd.com) Cell: +8801730019572 Blog:
>>>> khayer.wordpress.com
>>>> _______________________________________________ mapserver-users
>>>> mailing list mapserver-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
