[mapserver-users] Fatal error: Call to undefined function dl() in C:\ms4w\Apache\htdocs\phpmapscript.php on line 5
Milo van der Linden mlinden at zeelandnet.nl
Mon Nov 30 21:59:47 PST 2009
Dear geetha,
This has nothing to do with mapserver/mapscript, but is a php error. The
dl method is (correct me if I am wrong) a little outdated and has to
specifically be set to ENABLED in the php.ini.
Please google a bit on the dl error and see what parameter you need to
change (sorry that I cannot give you a full answer, but I am on 3G in a
train and unable to do some serious googlin')
On Tue, 2009-12-01 at 00:37 -0500, geetha at ttkmaps.com wrote:
> Hi all,
>   I tried to install php/mapscript in windows,I get the above error.I
> use mapserver version 5.4.2,Apache 2.2.11,PHP 5.3.Php works fine.Im
> able to run files with .php extension,but the below coding produces
> error:
> <HTML>
> <BODY>
> <?php
> dl("php_mapscript.dll");
> phpinfo();
> </BODY>
> </HTML>
> My php_mapscript.dll is in ..php/ext folder by default.My php.ini &
> php.exe is in /ms4w/Apache/cgi-bin.Is there any other dll i should
> add?It is said php/mapscript is preconfigured right...then what might
> be wrong?Thanks in advance.
> NewUser.
> mapserver-users at lists.osgeo.org
More information about the MapServer-users mailing list
