[mapserver-users] Fatal error: Call to undefined function dl() in C:\ms4w\Apache\htdocs\phpmapscript.php on line 5
new geetha at ttkmaps.com
Mon Nov 30 23:18:49 PST 2009
No,i am still not able to get it.It was given in
http://www.maptools.org/ms4w/index.phtml?page=README_INSTALL.html
troubleshooting part, to check for dll errors using cmd prompt.I did so,but
it gives file info.
newuser.
Milo van der Linden-3 wrote:
> Hello Geetha,
> Does this mean that the problem is solved?
> On Mon, 2009-11-30 at 22:51 -0800, new wrote:
>> Thanks milo,
>>     I checked with php.ini dl method is enabled.I tried in commmand
>> prompt
>> php C:/ms4w/Apache/htdocs/phpmapscript.php
>> No windows error was reported.
>> newuser.
>> > Dear geetha,
>> > This has nothing to do with mapserver/mapscript, but is a php error.
>> The
>> > dl method is (correct me if I am wrong) a little outdated and has to
>> > specifically be set to ENABLED in the php.ini.
>> > Please google a bit on the dl error and see what parameter you need to
>> > change (sorry that I cannot give you a full answer, but I am on 3G in a
>> > train and unable to do some serious googlin')
>> > On Tue, 2009-12-01 at 00:37 -0500, geetha at ttkmaps.com wrote:
>> >> Hi all,
>> >>   I tried to install php/mapscript in windows,I get the above error.I
>> >> use mapserver version 5.4.2,Apache 2.2.11,PHP 5.3.Php works fine.Im
>> >> able to run files with .php extension,but the below coding produces
>> >> error:
>> >> <HTML>
>> >> <BODY>
>> >> <?php
>> >> dl("php_mapscript.dll");
>> >> phpinfo();
>> >> </BODY>
>> >> </HTML>
>> >> My php_mapscript.dll is in ..php/ext folder by default.My php.ini &
>> >> php.exe is in /ms4w/Apache/cgi-bin.Is there any other dll i should
>> >> add?It is said php/mapscript is preconfigured right...then what might
>> >> be wrong?Thanks in advance.
>> >> NewUser.
>> >> _______________________________________________
>> >> mapserver-users mailing list
>> >> mapserver-users at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/mapserver-users
View this message in context: http://n2.nabble.com/Fatal-error-Call-to-undefined-function-dl-in-C-ms4w-Apache-htdocs-phpmapscript-php-on-line-5-tp4092107p4092286.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
More information about the MapServer-users mailing list
