[mapserver-users] query mode, multiple selections
Chris Kantarjiev
cak at speedgauge.net
Tue Sep 1 18:03:12 EDT 2009
Sure. The basic use case is:
User navigates to a particular, known, lat/lon as starting point; this can be by entering the known
lat/lon values, or by navigation around cities.
User then selects one or more links and can inspect attributes associated with those links - in
particular, link_id and direction. Initial selection could be by sweeping out an area, but should
also provide a way of adding/removing specific links from the selection (control-select).
Did that makes sense?
chris
Steve Lime wrote:
> You'd be surprised with what you can do with the CGI backend. It's certainly possible, with the right
> web client (e.g. something like GeoMoose or OpenLayers) to craft queries against the CGI to select
> one or many features from one or many layers using a point, box or arbitrary geometry. Perhaps if
> you could sketch out a use case or two...
> Steve
>>>> On 9/1/2009 at 12:49 PM, in message <4A9D5E9D.9000701 at speedgauge.net>, Chris
> Kantarjiev <cak at speedgauge.net> wrote:
>> I'm just starting to play with query mode and find it very useful. I have an
>> interaction style in
>> mind that would let me select and highlight several (possibly connected)
>> links in a layer in a
>> fairly interactive style (more like one would do with ArcGIS, I guess). I'm
>> pretty sure that I won't
>> be successful doing this with the basic CGI, and am overwhelmed by the
>> number of Ajax layers that I
>> might choose from.
>> Are there documents/pages out there that might give me some guidance about
>> what's possible with the
>> various packages?
>> Thanks,
>> chris
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
