[mapserver-users] Where to find symbols_mapinfo.sym
Daniel Morissette
dmorissette at mapgears.com
Wed Sep 2 09:25:30 EDT 2009
Marc Weustink wrote:
> Hi,
> When using styleitem "auto" on mapinfo source in mapserver, the doc says
> that for a quick solution I can use
> http://www2.dmsolutions.ca/msapps/yk_demo/etc/symbols_mapinfo.sym
> However access to that server is denied.
> Are there any other examples floating around I can try ?
The www2.dmsolutions.ca server had a hardware problem and has been
decommissioned, so we need to reinstall those demos somewhere else and
update the docs. There is already a ticket about this:
http://trac.osgeo.org/mapserver/ticket/3104
In the meantime, I have attached to this email a copy of the
symbols_mapinfo.sym file.
Daniel
Daniel Morissette
http://www.mapgears.com/
# This is aMapServer symbolset with symbol names used by the OGR-MapInfo
# driver, ofr use witht he STYLEITEM "AUTO" feature.
# 'default-circle' for thick lines
Symbol
Name 'default-circle'
Type ELLIPSE
Filled TRUE
Points
1 1
END
END
# 'default-marker' (plus sign) for cases where symbol name is not defined here
Symbol
Name 'default-marker'
Type VECTOR
Points
.5 0
.5 1
-99 -99
0 .5
1 .5
END
END
## The rest are MapInfo "old style" symbol names as returned by OGR
# 32 - filled square
Symbol
Name 'mapinfo-sym-32'
Type VECTOR
Filled TRUE
Points
0 1
0 0
1 0
1 1
0 1
END
END
# 33 - filled diamond
Symbol
Name 'mapinfo-sym-33'
Type VECTOR
Filled TRUE
Points
0 .5
.5 0
1 .5
.5 1
0 .5
END
END
# 34 - filled circle
Symbol
Name 'mapinfo-sym-34'
Type ELLIPSE
Filled TRUE
Points
1 1
END
END
# 35 - filled star
Symbol
Name 'mapinfo-sym-35'
Type VECTOR
Filled TRUE
Points
0 .375
.35 .375
.5 0
.65 .375
1 .375
.75 .625
.875 1
.5 .75
.125 1
.25 .625
END
END
# 36 - filled triangle
Symbol
Name 'mapinfo-sym-36'
Type VECTOR
Filled TRUE
Points
0 1
.5 0
1 1
0 1
END
END
# 38 - square
Symbol
Name 'mapinfo-sym-38'
Type VECTOR
Points
0 1
0 0
1 0
1 1
0 1
END
END
# 39 - diamond
Symbol
Name 'mapinfo-sym-39'
Type VECTOR
Points
0 .5
.5 0
1 .5
.5 1
0 .5
END
END
# 40 - circle
Symbol
Name 'mapinfo-sym-40'
Type ELLIPSE
Points
1 1
END
END
# 41 - star
Symbol
Name 'mapinfo-sym-41'
Type VECTOR
Points
0 .375
.35 .375
.5 0
.65 .375
1 .375
.75 .625
.875 1
.5 .75
.125 1
.25 .625
END
END
# 42 - triangle
Symbol
Name 'mapinfo-sym-42'
Type VECTOR
Points
0 1
.5 0
1 1
0 1
END
END
# 49 - plus
Symbol
Name 'mapinfo-sym-49'
Type VECTOR
Points
.5 0
.5 1
-99 -99
0 .5
1 .5
END
END
# 50 - cross
Symbol
Name 'mapinfo-sym-50'
Type VECTOR
Points
0 0
1 1
-99 -99
0 1
1 0
END
END
# 67 - tent
Symbol
Name 'mapinfo-sym-57'
Type VECTOR
Filled TRUE
Points
0 1
.5 0
1 1
.75 1
.5 .5
.25 1
0 1
END
END
