[mapserver-users] MapServer 5.2.1 performance
Christopher Schmidt
crschmidt at metacarta.com
Wed Sep 2 10:22:34 EDT 2009
On Wed, Sep 02, 2009 at 09:10:54AM -0500, Andy Colson wrote:
>> * I see that most of the layers spent around 0,015 seconds for each. Some layers spent around 0.25 seconds and I could see that these layers have few geometries very complex (I try to break these geometries in others simpler)
> As I see it, you have two options:
> 1) Make an individual request faster (hard to do)
> 2) Reduce the number of requests (easier, and different options)
> Do you really need all 120 layers? For one tile you have to make 120
> requests. If it takes 4 tiles to fill out your map, thats 4 * 120 = 480
> requests. If you could combine a few layers you would reduce the
> number of requests, and improve performance.
Er, I think your'e confused. His *mapfile* has 120 layers -- 40 of which
are 'within range', 80 of which are not, and he's putting those
40 layers into one tile. (This is large, but not excessive; the Boston
Freemap had something like 60 layers, and was a pretty simple map, all
things considered.)
I could be reading this wrong, but I think you're misunderstanding the
problem.
-- Chris
> Have you tried using multiple urls in OpenLayers?
> see:
> http://openlayers.org/dev/examples/multiserver.html
> Have you used firebug to watch it load? It has a nice pretty graph that
> shows which requests are concurrent, the time for each, etc, etc.
> If you can switch any of your layers to load as a single tile that would
> also cut down the number of requests (from 4 to 1 in the example above).
> -Andy
> mapserver-users at lists.osgeo.org
Christopher Schmidt
MetaCarta
