[mapserver-users] Character encoding in Query Results
Ben Madin
ben at remoteinformation.com.au
Tue Sep 8 17:47:40 EDT 2009
G'day.
Someone else has probably answered by now, but if it is a rendering
issue only you could try putting the character set into the !DOCTYPE
or meta headers.
cheers
Ben
On 09/09/2009, at 24:00 , mapserver-users-request at lists.osgeo.org wrote:
> From: mapcyp <erbugcelebi at gmail.com>
> Date: 8 September 2009 4:48:37 PM AWST
> To: mapserver-users at lists.osgeo.org
> Subject: [mapserver-users] Character encoding in Query Results
> Hi All,
> I am using a shapefile that contians Turkish charaters (iso-8859-9)
> in my
> MapServer application. I can display Labels properly on the map with
> the
> following configuration:
> LAYER
> LABEL
> MINDISTANCE 150
> PARTIALS false
> TYPE truetype
> FONT "serif"
> SIZE 10
> POSITION CC
> OUTLINECOLOR 254 254 254
> COLOR 0 0 0
> ENCODING ISO-8859-9
> END
> END
> My problem arise when I get the result of my queries. The query
> results
> contain wrong character as in the following.
> Name Population Area
> Dumlup�nar 2702 68km2 <<<<---- The character that has ? mark is
> wrong.
> I have tried to solve this problem by defining LAYER_ENCODING in LAYER
> section, and ENCODING in MAP section but the result was the same.
> Is there any suggestion to get the query results in ISO-8859-9 format?
> Thanks in advance.
Ben Madin
REMOTE INFORMATION
t : +61 8 9192 5455
f : +61 8 9192 5535
m : 0448 887 220
Broome WA 6725
Out here, it pays to know...
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090909/8a6b1823/attachment-0001.html
