[mapserver-users] Problem big filteritem (apache crash)
I-Real - Rob ter Haar
r.terhaar at i-real.nl
Wed Sep 16 05:16:17 EDT 2009
Hello All,
I have a problem with a filteritem witch contains +/- 11000 characters.
This are id's of points which I would show on a map. When I called the
page apache crasht. And in the coredump I see the following:
#0 0x00cf15bc in mempcpy () from /lib/libc.so.6
No symbol table info available.
#1 0x00ce6558 in _IO_default_xsputn_internal () from /lib/libc.so.6
#2 0x00cc2bd8 in vfprintf () from /lib/libc.so.6
#3 0x00cdbd4c in vsprintf () from /lib/libc.so.6
#4 0x00cc853e in sprintf () from /lib/libc.so.6
#5 0x070fa3f5 in msOracleSpatialLayerWhichShapes (layer=0x36393639, rect=
{minx = 1.7223872351905284e-47, miny = 1.1808818690463142e-95,
maxx = 2.0056059668611313e-76, maxy = 2.7151806783827087e-33}) at
maporaclespatial.c:670
success = <value optimized out>
i = -1081417209
function = 959197241
version = 909716537
query_str = "SELECT LOCATIEID, alarm_actief, NAAM, SHAPE FROM
(SELECT L.LOCATIEID AS LOCATIEID, LG.SHAPE, L.NAAM AS NAAM, L.ADRES,
L.PLAATS, alarm.NAAM Laatste_alarm, unixts_to_date(Alarm.TIJDSTIP_HOOG)
Actief_sin"...
table_name =
",4992,4993,4994,4995,4996,4997,4998,4999,5000,5001,5002,5003,5035,5036,5037,5038,5039,5040,5041,5042,5043,5044,5045,5046,5047,5048,5049,5050,5051,5052,5053,5054,5055,5056,5113,5396,5546,5547,5548,5549"...
geom_column_name =
",9647,9648,9649,9654,9655,9656,9657,9658,9659,9660,9661,9662,9663,9664,9665,9669,9670,9671,9672,9688"
unique =
",9624,9625,9626,9627,9628,9629,9630,9631,9632,9633,9634,9635,9636,9637,9641,9642,9643,9644,9645,9646"
srid =
",9604,9605,9606,9607,9608,9609,9610,9611,9612,9613,9614,9615,9616,9617,9618,9619,9620,9621,9622,9623"
adtp = (OCIDefine *) 0x3836392c
items = (OCIDefine **) 0x93b5560
dthand = (msOracleSpatialDataHandler *) 0x938e930
hand = (msOracleSpatialHandler *) 0x9436080
In the fields Table_name, geon_colomn_name, unique and srid are filled
with the string I assign to FilterItem.
Is this a bug or do I make a mistake?
I use the mapscript (php) to assign the variables.
Can anyone help me?
Met vriendelijke groet,
Rob ter Haar
*I-Real*
Postbus 593
7000 AN Doetinchem
*T:* +31 (0)314 366600
*F:* +31 (0)314 363410
*E:* r.terhaar at i-real.nl <mailto:r.terhaar at i-real.nl>
*I:* www.i-real.nl <http://www.i-real.nl>
De informatie in dit e-mailbericht is uitsluitend bestemd voor de
geadresseerde.
Verstrekking aan en gebruik door anderen is niet toegestaan.
Door de elektronische verzending van het bericht, kunnen er geen rechten
worden ontleend aan de informatie.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090916/684c1ea4/attachment.html
