[mapserver-users] Problem with WMS Request through Mapserver
Yewondwossen Assefa
yassefa at dmsolutions.ca
Fri Sep 18 16:40:26 EDT 2009
Hi There,
Maybe you could do a GetCapabilities request on the WMS server and see
what are the types of exceptions that are supported by the server. It
might support other exceptions than the application/vnd.ogc.se_inimage.
if that is the case, you can set a layer level metadata called
ows_exception to the one that is supported. Something like:
METADATA
"ows_exception" "supported_exception"
END
best regards,
Robert Hicks wrote:
> I am making a WMS request from a simple OpenLayers client to Mapserver
> which is in turn calling another WMS server. My problem is, is that the
> call from MapServer to the secondary WMS server has an extra paramater
> tacked on: EXCEPTIONS=application/vnd.ogc.se_inimage (I saw this going
> through Wire Shark which is a packet sniffer), and when I grab the exact
> call, strip out that argument, the image returns fine. Is there a way to
> specify, in the map file, that I either do not want this? Note, that the
> request coming from OpenLayers does not have this argument (I found this
> out via Firebug).
> Here is a layer out of my map file:
> LAYER
> # name of layer
> NAME "Infrared1995"
> GROUP "newjerseywms"
> # what type of data is this?
> TYPE RASTER
> # always returned with interface
> STATUS ON
> CONNECTION "http://njwebmap.state.nj.us/njorthos"
> CONNECTIONTYPE WMS
> METADATA
> "wms_srs" "EPSG:4326"
> "wms_name" "Infrared1995"
> "wms_server_version" "1.1.1"
> "wms_format" "image/png"
> END
> END
> Thanks!
> web http://www.hyxspace.com
> aim hyx1138
> mapserver-users at lists.osgeo.org
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
