[mapserver-users] Invalid format for the EXCEPTION parameter
Yewondwossen Assefa
yassefa at dmsolutions.ca
Tue Sep 22 21:24:09 EDT 2009
Robert Sanson wrote:
> Hi Assefa
> Unfortunately not - it seems to be hardcoded in. Can I get Mapserver to
> only offer WMS version 1.1.1?
Not at this point; all supported versions are exposed by default. I
think supporting application/vnd.ogc.se_xml could be done for 1.3.0
unless it prevents MapServer from passing all OGC tests (for
certification purpose). I will check the tests and update before the
5.6.0 release.
regards,
> Thanks,
> Robert
> >>> Yewondwossen Assefa <yassefa at dmsolutions.ca> 23/09/2009 12:48 p.m. >>>
> Hi There,
> Valid EXCEPTIONS values for wms 1.3.0 are INIMAGE, BLANK, XML.
> application/vnd.ogc.se_XML was used for previous versions. Do you have
> any control on this parameter from ArcMap/ArcCatalog ?
> regards
> > I have a 5.4.2 version of Mapserver (MS4W) configured for WMS access.
> > OpenLayers is accessing it fine, however, ArcMap / ArcCatalog v 9.3 is
> > giving me an Error message:
> > WMS service exceptions:-Service Error Code:InvalidFormat
> > Service Error Description: msWMSLoadGetMapParams(): WMS server error.
> > Invalid format for the EXCEPTION parameter.
> > Looking in the Apache access.log file I see:
> > "GET
> /cgi-bin/mapserv.exe?map=/ms4w/apps/service/nztm.map&VERSION=1.3.0&REQUEST=GetMap&CRS=EPSG:2193&BBOX=773500,4615000,2602100,5973130.71761735
> &WIDTH=82&HEIGHT=111&LAYERS=crs_roads,crs_address,centroids,main_gates,main_homesteads,stockyards,dairysheds,synlait,apiaries,copyright
> &STYLES=,,,,,,,,,&EXCEPTIONS=application/vnd.ogc.se_XML&FORMAT=image/png&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE
> > HTTP/1.0"
> > In my various layer Metadata I have the following:
> > METADATA
> > "ows_title" "apiaries"
> > "ows_abstract" "These are the registered apiaries from the
> Apiary DB"
> > "wms_srs" "EPSG:2193"
> > "wms_opaque" "0"
> > "wms_group_title" "API"
> > "wms_group_abstract" "Apiaries"
> > "ows_extent" "773500 4615000 2602100 6324500"
> > "wms_dataurl_format" "text/html"
> > "gml_include_items" "all"
> > "wms_exceptions_format" "application/vnd.ogc.se_xml"
> > END
> > Many thanks,
> > Robert Sanson
> The contents of this email are confidential to AsureQuality. If you have received this communication in error please notify the sender immediately and delete the message and any attachments. The opinions expressed in this email are not necessarily those of AsureQuality. This message has been scanned for known viruses before delivery. AsureQuality supports the Unsolicited Electronic Messages Act 2007. If you do not wish to receive similar communications in future, please notify the sender of this message.
> This message has been scanned for malware by SurfControl plc.
> www.surfcontrol.com <http://www.surfcontrol.com/>
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
