[mapserver-users] mapserver files to subdomain results in
'500Internal Server Error' when mapserv executable accessed through url
Ted Spradley
tspradley at snoogems.com
Wed Sep 23 01:09:26 EDT 2009
Daniel Morissette wrote:
> Ted Spradley wrote:
>> Then I tried setting the environment variable by adding 'SetEnv
>> LD_LIBRARY_PATH /usr/local/lib'
>> to the /var/www/vhosts/domain/conf/httpd.include file as follows:
>> <VirtualHost xxx.xxx.xxx.xx:80>
>> ServerName maps.domain.com:80
>> SuexecUserGroup snoogadmin psacln
>> ServerAdmin "admin at domain.com"
>> DocumentRoot /var/www/vhosts/domain.com/subdomains/maps/httpdocs
>> CustomLog /var/www/vhosts/domain.com/statistics/logs/access_log
>> plesklog
>> ErrorLog /var/www/vhosts/domain.com/statistics/logs/error_log
>> ScriptAlias /cgi-bin/ /var/www/cgi-bin/
>> SetEnv LD_LIBRARY_PATH /usr/local/lib
>> and restarted Apache, but with the same result of '500 Internal Server
>> Error'.
> You also need to tell Apache to pass the env var to the CGI environment
> using PassEnv:
> PassEnv LD_LIBRARY_PATH
> Daniel
> Daniel Morissette
> http://www.mapgears.com/
> mapserver-users at lists.osgeo.org
Thanks Daniel. It appears I made something simple, complicated.
Ultimately the solution was:
1. setting:
'Options -Includes -ExecCGI' whereas prior to this options were 'Options
-Includes +ExecCGI'
2. removing the ScriptAlias from the <virtualhost> context.
'http://maps.domain.com/cgi-bin/mapserv' now returns 'No query information
to decode. QUERY_STRING is set, but empty. ' as expected.
I include various unsuccessful attempts in the event it is helpful to
someone in the future.
I entered the pass env directive into httpd.conf:
Apache gave the following warning and the internal server error was still
returned.
'Starting httpd: [Tue Sep 22 15:46:08 2009] [warn] PassEnv variable
LD_LIBRARY_PATH was undefined'
I tried entering the pass env directive:
1. after the SetEnv directive :
SetEnv LD_LIBRARY_PATH "/lib:/usr/lib:/usr/local/lib"
2. without using the SetEnv directive
3. in Context server config, virtual host, and directory in the above two
combinations
Thanks to all,
Ted S.
View this message in context: http://n2.nabble.com/mapserver-files-to-subdomain-results-in-500-Internal-Server-Error-when-mapserv-executable-accessed-tl-tp3687559p3697577.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
