[mapserver-users] Is It Possible To Draw The Map Without Reading
Joined Tables?
Richard Greenwood
richard.greenwood at gmail.com
Thu Sep 24 22:17:41 EDT 2009
On Thu, Sep 24, 2009 at 5:51 PM, James Card <James.Card at calcad.com> wrote:
> We have a map that includes four layers that have OGR joins to database
> tables. The joined tables are used only for queries, not for theming or
> labeling the layers. When we compare performance of those same layers
> without the database joins we discover that maps are drawn in 1/3 - 1/5 of
> the time that's required for the joined layers.
> Is it possible to force MapServer to draw layers without reading the joined
> tables, but still have the tabular data available for queries?
Sure. Two approaches come to mind:
1. Define the layer twice, once without the join for spatial
rendering, and then again with a different name, including the joins,
for attribute queries.
2. Use 2 different map files. One for rendering, one for queries.
I'd recommend the second approach because it gives you some nice
flexibility, especailly with HEADER and FOOTER templates.
Regards,
Richard Greenwood
www.greenwoodmap.com
