[mapserver-users] RE: Connection between mapserver and postgresql
is getting disrupted
Suman Chatterjee
schatterjee at addisontx.gov
Tue Sep 29 10:29:14 EDT 2009
Hi Andy,
Thanks! As per your advice I am posting the details below here. You can then post it in proper place.
PostGIS version - 1.3.6
Postgresql - 8.3
Postgresql.conf settings:
# PostgreSQL configuration file
# This file consists of lines of the form:
# name = value
# (The "=" is optional.) Whitespace may be used. Comments are introduced with
# "#" anywhere on a line. The complete list of parameter names and allowed
# values can be found in the PostgreSQL documentation.
# The commented-out settings shown in this file represent the default values.
# Re-commenting a setting is NOT sufficient to revert it to the default value;
# you need to reload the server.
# This file is read on server startup and when the server receives a SIGHUP
# signal. If you edit the file on a running system, you have to SIGHUP the
# server for the changes to take effect, or use "pg_ctl reload". Some
# parameters, which are marked below, require a server shutdown and restart to
# take effect.
# Any parameter can also be given as a command-line option to the server, e.g.,
# "postgres -c log_connections=on". Some paramters can be changed at run time
# with the "SET" SQL command.
# Memory units: kB = kilobytes MB = megabytes GB = gigabytes
# Time units: ms = milliseconds s = seconds min = minutes h = hours d = days
# FILE LOCATIONS
# The default values of these variables are driven from the -D command-line
# option or PGDATA environment variable, represented here as ConfigDir.
#data_directory = 'ConfigDir' # use data in another directory
# (change requires restart)
#hba_file = 'ConfigDir/pg_hba.conf' # host-based authentication file
#ident_file = 'ConfigDir/pg_ident.conf' # ident configuration file
# If external_pid_file is not explicitly set, no extra PID file is written.
#external_pid_file = '(none)' # write an extra PID file
# CONNECTIONS AND AUTHENTICATION
# - Connection Settings -
listen_addresses = '*' # what IP address(es) to listen on;
# comma-separated list of addresses;
# defaults to 'localhost', '*' = all
port = 5432 # (change requires restart)
max_connections = 100 # (change requires restart)
# Note: Increasing max_connections costs ~400 bytes of shared memory per
# connection slot, plus lock space (see max_locks_per_transaction). You might
# also need to raise shared_buffers to support more connections.
#superuser_reserved_connections = 3 # (change requires restart)
#unix_socket_directory = '' # (change requires restart)
#unix_socket_group = '' # (change requires restart)
#unix_socket_permissions = 0777 # begin with 0 to use octal notation
#bonjour_name = '' # defaults to the computer name
# - Security and Authentication -
#authentication_timeout = 1min # 1s-600s
#ssl = off # (change requires restart)
#ssl_ciphers = 'ALL:!ADH:!LOW:!EXP:!MD5:@STRENGTH' # allowed SSL ciphers
#password_encryption = on
#db_user_namespace = off
# Kerberos and GSSAPI
#krb_server_keyfile = '' # (change requires restart)
#krb_srvname = 'postgres' # (change requires restart, Kerberos only)
#krb_server_hostname = '' # empty string matches any keytab entry
#krb_caseins_users = off # (change requires restart)
#krb_realm = '' # (change requires restart)
# - TCP Keepalives -
# see "man 7 tcp" for details
#tcp_keepalives_idle = 0 # TCP_KEEPIDLE, in seconds;
# 0 selects the system default
#tcp_keepalives_interval = 0 # TCP_KEEPINTVL, in seconds;
#tcp_keepalives_count = 0 # TCP_KEEPCNT;
# RESOURCE USAGE (except WAL)
# - Memory -
shared_buffers = 32MB # min 128kB or max_connections*16kB
#temp_buffers = 8MB # min 800kB
#max_prepared_transactions = 5 # can be 0 or more
# Note: Increasing max_prepared_transactions costs ~600 bytes of shared memory
# per transaction slot, plus lock space (see max_locks_per_transaction).
#work_mem = 1MB # min 64kB
#maintenance_work_mem = 16MB # min 1MB
#max_stack_depth = 2MB # min 100kB
# - Free Space Map -
max_fsm_pages = 204800 # min max_fsm_relations*16, 6 bytes each
#max_fsm_relations = 1000 # min 100, ~70 bytes each
# - Kernel Resource Usage -
#max_files_per_process = 1000 # min 25
#shared_preload_libraries = '' # (change requires restart)
# - Cost-Based Vacuum Delay -
#vacuum_cost_delay = 0 # 0-1000 milliseconds
#vacuum_cost_page_hit = 1 # 0-10000 credits
#vacuum_cost_page_miss = 10 # 0-10000 credits
#vacuum_cost_page_dirty = 20 # 0-10000 credits
#vacuum_cost_limit = 200 # 1-10000 credits
# - Background Writer -
#bgwriter_delay = 200ms # 10-10000ms between rounds
#bgwriter_lru_maxpages = 100 # 0-1000 max buffers written/round
#bgwriter_lru_multiplier = 2.0 # 0-10.0 multipler on buffers scanned/round
# WRITE AHEAD LOG
# - Settings -
#fsync = on # turns forced synchronization on or off
#synchronous_commit = on # immediate fsync at commit
#wal_sync_method = fsync # the default is the first option
# supported by the operating system:
# open_datasync
# fdatasync
# fsync
# fsync_writethrough
# open_sync
#full_page_writes = on # recover from partial page writes
#wal_buffers = 64kB # min 32kB
#wal_writer_delay = 200ms # 1-10000 milliseconds
#commit_delay = 0 # range 0-100000, in microseconds
#commit_siblings = 5 # range 1-1000
# - Checkpoints -
#checkpoint_segments = 3 # in logfile segments, min 1, 16MB each
#checkpoint_timeout = 5min # range 30s-1h
#checkpoint_completion_target = 0.5 # checkpoint target duration, 0.0 - 1.0
#checkpoint_warning = 30s # 0 is off
# - Archiving -
#archive_mode = off # allows archiving to be done
#archive_command = '' # command to use to archive a logfile segment
#archive_timeout = 0 # force a logfile segment switch after this
# time; 0 is off
# QUERY TUNING
# - Planner Method Configuration -
#enable_bitmapscan = on
#enable_hashagg = on
#enable_hashjoin = on
#enable_indexscan = on
#enable_mergejoin = on
#enable_nestloop = on
#enable_seqscan = on
#enable_sort = on
#enable_tidscan = on
# - Planner Cost Constants -
#seq_page_cost = 1.0 # measured on an arbitrary scale
#random_page_cost = 4.0 # same scale as above
#cpu_tuple_cost = 0.01 # same scale as above
#cpu_index_tuple_cost = 0.005 # same scale as above
#cpu_operator_cost = 0.0025 # same scale as above
#effective_cache_size = 128MB
# - Genetic Query Optimizer -
#geqo = on
#geqo_threshold = 12
#geqo_effort = 5 # range 1-10
#geqo_pool_size = 0 # selects default based on effort
#geqo_generations = 0 # selects default based on effort
#geqo_selection_bias = 2.0 # range 1.5-2.0
# - Other Planner Options -
#default_statistics_target = 10 # range 1-1000
#constraint_exclusion = off
#from_collapse_limit = 8
#join_collapse_limit = 8 # 1 disables collapsing of explicit
# JOIN clauses
# ERROR REPORTING AND LOGGING
# - Where to Log -
log_destination = 'stderr' # Valid values are combinations of
# stderr, csvlog, syslog and eventlog,
# depending on platform. csvlog
# requires logging_collector to be on.
# This is used when logging to stderr:
logging_collector = on # Enable capturing of stderr and csvlog
# into log files. Required to be on for
# csvlogs.
# These are only used if logging_collector is on:
#log_directory = 'pg_log' # directory where log files are written,
# can be absolute or relative to PGDATA
#log_filename = 'postgresql-%Y-%m-%d_%H%M%S.log' # log file name pattern,
# can include strftime() escapes
#log_truncate_on_rotation = off # If on, an existing log file of the
# same name as the new log file will be
# truncated rather than appended to.
# But such truncation only occurs on
# time-driven rotation, not on restarts
# or size-driven rotation. Default is
# off, meaning append to existing files
# in all cases.
#log_rotation_age = 1d # Automatic rotation of logfiles will
# happen after that time. 0 to disable.
#log_rotation_size = 10MB # Automatic rotation of logfiles will
# happen after that much log output.
# 0 to disable.
# These are relevant when logging to syslog:
#syslog_facility = 'LOCAL0'
#syslog_ident = 'postgres'
# - When to Log -
#client_min_messages = notice # values in order of decreasing detail:
# debug5
# debug4
# debug3
# debug2
# debug1
# log
# notice
# warning
# error
#log_min_messages = notice # values in order of decreasing detail:
# debug5
# debug4
# debug3
# debug2
# debug1
# info
# notice
# warning
# error
# log
# fatal
# panic
#log_error_verbosity = default # terse, default, or verbose messages
#log_min_error_statement = error # values in order of decreasing detail:
# debug5
# debug4
# debug3
# debug2
# debug1
# info
# notice
# warning
# error
# log
# fatal
# panic (effectively off)
#log_min_duration_statement = -1 # -1 is disabled, 0 logs all statements
# and their durations, > 0 logs only
# statements running at least this time.
#silent_mode = off # DO NOT USE without syslog or
# logging_collector
# - What to Log -
#debug_print_parse = off
#debug_print_rewritten = off
#debug_print_plan = off
#debug_pretty_print = off
#log_checkpoints = off
#log_connections = off
#log_disconnections = off
#log_duration = off
#log_hostname = off
log_line_prefix = '%%t ' # special values:
# %u = user name
# %d = database name
# %r = remote host and port
# %h = remote host
# %p = process ID
# %t = timestamp without milliseconds
# %m = timestamp with milliseconds
# %i = command tag
# %c = session ID
# %l = session line number
# %s = session start timestamp
# %v = virtual transaction ID
# %x = transaction ID (0 if none)
# %q = stop here in non-session
# processes
# e.g. '<%u%%%d> '
#log_lock_waits = off # log lock waits >= deadlock_timeout
#log_statement = 'none' # none, ddl, mod, all
#log_temp_files = -1 # log temporary files equal or larger
# than specified size;
# -1 disables, 0 logs all temp files
#log_timezone = unknown # actually, defaults to TZ environment
# setting
# RUNTIME STATISTICS
# - Query/Index Statistics Collector -
#track_activities = on
#track_counts = on
#update_process_title = on
# - Statistics Monitoring -
#log_parser_stats = off
#log_planner_stats = off
#log_executor_stats = off
#log_statement_stats = off
# AUTOVACUUM PARAMETERS
#autovacuum = on # Enable autovacuum subprocess? 'on'
# requires track_counts to also be on.
#log_autovacuum_min_duration = -1 # -1 disables, 0 logs all actions and
# their durations, > 0 logs only
# actions running at least that time.
#autovacuum_max_workers = 3 # max number of autovacuum subprocesses
#autovacuum_naptime = 1min # time between autovacuum runs
#autovacuum_vacuum_threshold = 50 # min number of row updates before
# vacuum
#autovacuum_analyze_threshold = 50 # min number of row updates before
# analyze
#autovacuum_vacuum_scale_factor = 0.2 # fraction of table size before vacuum
#autovacuum_analyze_scale_factor = 0.1 # fraction of table size before analyze
#autovacuum_freeze_max_age = 200000000 # maximum XID age before forced vacuum
#autovacuum_vacuum_cost_delay = 20 # default vacuum cost delay for
# autovacuum, -1 means use
# vacuum_cost_delay
#autovacuum_vacuum_cost_limit = -1 # default vacuum cost limit for
# vacuum_cost_limit
# CLIENT CONNECTION DEFAULTS
# - Statement Behavior -
#search_path = '"$user",public' # schema names
#default_tablespace = '' # a tablespace name, '' uses the default
#temp_tablespaces = '' # a list of tablespace names, '' uses
# only default tablespace
#check_function_bodies = on
#default_transaction_isolation = 'read committed'
#default_transaction_read_only = off
#session_replication_role = 'origin'
#statement_timeout = 0 # 0 is disabled
#vacuum_freeze_min_age = 100000000
#xmlbinary = 'base64'
#xmloption = 'content'
# - Locale and Formatting -
datestyle = 'iso, mdy'
#timezone = unknown # actually, defaults to TZ environment
# setting
#timezone_abbreviations = 'Default' # Select the set of available time zone
# abbreviations. Currently, there are
# Default
# Australia
# India
# You can create your own file in
# share/timezonesets/.
#extra_float_digits = 0 # min -15, max 2
#client_encoding = sql_ascii # actually, defaults to database
# encoding
# These settings are initialized by initdb, but they can be changed.
lc_messages = 'English, United States' # locale for system error message
# strings
lc_monetary = 'English, United States' # locale for monetary formatting
lc_numeric = 'English, United States' # locale for number formatting
lc_time = 'English, United States' # locale for time formatting
# default configuration for text search
default_text_search_config = 'pg_catalog.simple'
# - Other Defaults -
#explain_pretty_print = on
#dynamic_library_path = '$libdir'
#local_preload_libraries = ''
# LOCK MANAGEMENT
#deadlock_timeout = 1s
#max_locks_per_transaction = 64 # min 10
# Note: Each lock table slot uses ~270 bytes of shared memory, and there are
# max_locks_per_transaction * (max_connections + max_prepared_transactions)
# lock table slots.
# VERSION/PLATFORM COMPATIBILITY
# - Previous PostgreSQL Versions -
#add_missing_from = off
#array_nulls = on
#backslash_quote = safe_encoding # on, off, or safe_encoding
#default_with_oids = off
#escape_string_warning = on
#regex_flavor = advanced # advanced, extended, or basic
#sql_inheritance = on
#standard_conforming_strings = off
#synchronize_seqscans = on
# - Other Platforms and Clients -
#transform_null_equals = off
# CUSTOMIZED OPTIONS
#custom_variable_classes = '' # list of custom variable class names
Thanks,
Suman
-----Original Message-----
Sent: Monday, September 28, 2009 10:58 AM
To: Suman Chatterjee
Cc: 'mapserver-users at lists.osgeo.org'
Subject: Re: Connection between mapserver and postgresql is getting disrupted
Suman Chatterjee wrote:
> Hi Andy,
> I could open the log file. The following error was written into it.
> FATAL: could not reattach to shared memory (Key=224, addr=025F0000): 487
> Is there anything that can be done to solve the problem?
> Thanks
> Suman
Again, looks like a windows thing. I've never run pg on windows. I
think that's a message you'd need to post to the postgres newsgroup and
see what they say. (I'm already a user on the pg-general group, I'd be
happy to post it if you wanted me to.)
I dont recall, what version of pg is this. And can you post your
uncommented postgres.conf settings. (They pg newsgroup will want to see
all this. You can post it for them there, or post it here and I'll post
it there.)
If you're running an old version of pg on windows, the first thing
they'll do is recommend you upgrade. Just a warning.
-Andy
This e-mail and any files or attachments transmitted with it contains Information that is confidential and privileged. This document may contain Protected Health Information (PHI) or other information that is intended only for the use of the individual(s) and entity(ies) to whom it is addressed. If you are the intended recipient, further disclosures are prohibited without proper authorization. If you are not the intended recipient, any disclosure, copying, printing, or use of this information is strictly prohibited and possibly a violation of federal or state law and regulations. If you have received this information in error, please delete it and notify Hamid Khaleghipour at 972-450-2868 immediately. Thank you.
