[mapserver-users] JOIN SHP and CSV
Stefan Schantz
sschantz at bfs.de
Wed Sep 30 07:42:21 EDT 2009
Hello,
although I 've read several informations (in this user list, mapserver
documentation) about joining datas von a csv-file to a shp-file, I still
get the error message "Content-type: application/vnd.ogc.se_xml
msDBFJoinConnect(): Unable to access file.
(../../../../daten/vektordaten/utm/studios/europa_sonnenstudio.csv)"
I 've tried already several things like putting csv-file at the same
place as the mapfile, chmod 777 , but I always got the same message.
Any ideas? Thanks!
My mapfile looks like:
LAYER
NAME "europa"
TYPE POLYGON
STATUS ON
DUMP TRUE
DATA "europa"
JOIN
NAME "tab"
TABLE
"../../../../daten/vektordaten/utm/studios/europa_sonnenstudio.csv"
FROM "NAME"
TO "NAME"
TYPE ONE-TO-ONE
END
PROJECTION
"init=epsg:4326"
END
METADATA
WMS_SRS "EPSG:25832 EPSG:4326 EPSG:32632 EPSG:31466
EPSG:31467 EPSG:31468"
WMS_TITLE "Sonnenstudio"
WMS_ABSTRACT "blabla"
END
LABELITEM 'NAME'
CLASS
END # CLASS
CLASS
END # CLASS
TEMPLATE "../templates/getFeature_sonnenstudio.html"
The path to the data is
"/daten/vektordaten/utm/studios/europa_sonnenstudio.csv"
303140 -rwxrwxrwx 1 ssh-m gdi 2229 Sep 30 11:27
path to the mapfile is "/data/umn/abc/map/studio.map"
The information of the csv-data is:
ogrinfo europa_sonnenstudio.csv europa_sonnenstudio -summary
INFO: Open of `europa_sonnenstudio.csv'
using driver `CSV' successful.
Layer name: europa_sonnenstudio
Geometry: None
Feature Count: 54
Layer SRS WKT:
(unknown)
TEXT: String (0.0)
DATUM: String (0.0)
The information of the shp-data is:
ogrinfo europa.shp europa -summary
INFO: Open of `europa.shp'
using driver `ESRI Shapefile' successful.
Layer name: europa
Geometry: Polygon
Feature Count: 54
Extent: (-31.265747, 32.397476) - (69.070320, 81.857368)
Layer SRS WKT:
(unknown)
Greetings from the Bavarian-Oktoberfest
Stefan
