[mapserver-users] Loadquery in MAPSERVER 5.6.1
Daniel Morissette
dmorissette at mapgears.com
Thu Apr 1 11:34:55 EDT 2010
Alexandre Trindade wrote:
> Thanks for reply my question. You're right, using the file extension
> .qy solved this problem , really thanks.
> But appears a new problem, my routine accumulates results using
> successive queryByIndex() and saves in query file for read later ( works
> fine in MS 5.2.1 ). However in the Mapserver 5.6.1 her saved only last
> queryindex result.
> foreach ($shp as $indx)
> { @$this->mapa->querybyindex($indxlayer,-1,$indx,MS_TRUE); }
> $this->mapa->savequery($this->qyfile);
> Is no longer possible using this method this way, or I'm not setting right?
Alexandre,
Please do not bottom-post at the end of a very long email... just a hint
to increase your chances of getting a response. You're lucky that I
scrolled all the way down the very long email to read your question... I
usually don't.
Back to your question: I don't know if cumulative queries were expected
to be supported in the past, and should be now. Hopefully Steve will
read this and comment. If he doesn't then I suggest you post the
question again clearly in a new post.
Daniel
Daniel Morissette
http://www.mapgears.com/
