[mapserver-users] Loadquery in MAPSERVER 5.6.1
Edmar Moretti
edmar.moretti at terra.com.br
Thu Apr 1 21:12:08 EDT 2010
In the post
http://n2.nabble.com/php-mapscript-loadQuery-problem-td4496775.html is
shown the .qy file structure (by Steve Lime):
Line - Contents
0 - magic string
1 - mode, type (single or multiple), Qlaya, slayer
2 - point x, y point, buffer, max results (queryByPoint)
3 - query rect (minx, miny, maxx, maxy) (queryByRect)
4 - shp index, tile index, clear cache flag (queryByIndex)
5 - qitem or NULL (queryByAttribute)
6 - QString or NULL
7 - operator (used by WFS)
8 + - query shape (queryByShape)
My question is: how to include more than one element using shp index?
Daniel Morissette escreveu:
> Alexandre Trindade wrote:
>> Thanks for reply my question. You're right, using the file extension
>> .qy solved this problem , really thanks.
>> But appears a new problem, my routine accumulates results using
>> successive queryByIndex() and saves in query file for read later (
>> works fine in MS 5.2.1 ). However in the Mapserver 5.6.1 her saved
>> only last queryindex result.
>> foreach ($shp as $indx)
>> { @$this->mapa->querybyindex($indxlayer,-1,$indx,MS_TRUE); }
>> $this->mapa->savequery($this->qyfile);
>> Is no longer possible using this method this way, or I'm not setting
>> right?
> Alexandre,
> Please do not bottom-post at the end of a very long email... just a
> hint to increase your chances of getting a response. You're lucky that
> I scrolled all the way down the very long email to read your
> question... I usually don't.
> Back to your question: I don't know if cumulative queries were
> expected to be supported in the past, and should be now. Hopefully
> Steve will read this and comment. If he doesn't then I suggest you
> post the question again clearly in a new post.
> Daniel
Skype/MSN:
edmar.moretti
Twitter:
@edmarmoretti
Blogs:
http://edmarmoretti.blogspot.com/
http://mapasnaweb.blogspot.com/
Ohloh:
https://www.ohloh.net/accounts/edmarmoretti
Geógrafos:
http://geografos.ning.com/profile/EdmarMoretti
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100401/ac1b8b85/attachment.html
