[mapserver-users] record element in query header
Daniel Morissette
dmorissette at mapgears.com
Wed Apr 7 14:16:44 EDT 2010
Steve.Toutant at inspq.qc.ca wrote:
> If I put [provincename] in the template I got the value, per example
> In the Template
> [lrn]: [provincename] - [elementname]<br>
> The result is:
> 1: Québec - blabla 1
> 2: Québec - blabla 2
> 3: Québec - blabla 3
> But I don't want to put it in the template since the same information
> will be repeated.
> thanks for your help!
I'm not exactly sure if a field name should be supported in the header
template, but based on a quick browse of the code there are two other
ways you could possibly pass the information (depending on what you have
on the client side):
1- You can use parameters from the URL in a template tag. e.g. if you
pass myprov=Quebec in the URL then you should be able to use [myprov] in
your template.
2- You can reference layer-level metadata in query templates using
[metadata_...]
(Those are untested hints based on a quick browse of the source)
Daniel
Daniel Morissette
http://www.mapgears.com/
