[mapserver-users] Dynamically generated Raster images in mapfile
Heiko Schröter
schroete at iup.physik.uni-bremen.de
Thu Apr 8 08:27:45 EDT 2010
Hello,
i need to create Raster images on the fly and place them on a map generated with Mapserver.
The time needed for generating these images is not crucial.
An external script is triggered to generate these images.
1) Is it possible to define in a mapfile a "data/image source" coming from a script ?
or
2) Is it possible to rediret the output of the script as input to mapserver ?
Stepping through the docs the only solution i can think of in the moment is to generate a temp.img (and temp.tlw)and pass that filename as variable to the DATA tag inside the mapfile.
Any pointer to some more infos is highly appreciated.
Preprocessing is not a solution since we have dozends of options for generating the images.
Thanks and Regards
Heiko
