[mapserver-users] can not compile arcsde 9.3 with mapserver 5.4
Jachym Cepicky jachym.cepicky at gmail.com
Sun Apr 11 23:00:20 PDT 2010
slowly, I'm approaching. Our customer had to write to out local service
provider of ESRI and they had to write to ESRI and request for the
header files (I can not find the page, where it was written, but the
header files should just arrive from U.S. here).
So, now I "should" be able to compile
Thanks
Jachym
Lime, Steve D (DNR) píše v St 07. 04. 2010 v 16:40 -0500:
> Don't know if success was had or not. The standard 9.3 disks I had access to did not have the headers available. Must need some super secret handshake to get them. Anyway, I just copied the 9.2 headers into the same spot in the 9.3 directories  and it works just fine. Don't know that I'd recommend that approach in lieu of learning the super secret handshake but it worked here in a pinch...
> Steve
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Huey Brantley
> Sent: Thursday, March 18, 2010 10:44 PM
> To: Jachym Cepicky
> Cc: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] can not compile arcsde 9.3 with mapserver 5.4
> Compile it against the SDE SDK, not where you have SDE installed.
> My configure:
> ./configure \
>    --with-php=/usr/local \
>    --with-proj=/usr/local \
>    --with-gd=/usr/local \
>    --with-jpeg=/usr/local \
>    --with-png=/usr/local \
>    --with-sde=/u01/arcgis93sdk/sdeexe93/ \
>    --with-sde-version=93 \
>    --with-wfs \
>    --with-ogr=/usr/local/bin/gdal-config \
>    --with-gdal=/usr/local/bin/gdal-config \
>    --with-freetype \
>    --with-tiff \
>    --with-agg \
>    --with-curl \
>    --enable-debug
> Jachym Cepicky wrote:
> > Hi,
> > I'm not able to get arcsde 9.3.0 compiled with mapserver (5.4), on Linux
> > I use
> > ./configure --with-sde=/opt/arcsde/9.3.0/sdeexe93/ --with-sde-version=''
> > the arcsde installation directory containes (among others) file
> > libsde.so
> > nut not "*.a" file or "*.h" files
> > however, I get
> > configure: error: "Could not find sdetype.h or libsde.a/libsde.so in
> > /opt/arcsde/9.3.0/sdeexe93/."
> > Any hint?
> > Thanks
> > Jachym
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
PGP Public key: http://les-ejk.cz/pgp/JachymCepicky.pgp
Desc: Toto je digit?ln? podepsan? ??st zpr?vy
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100412/55badd44/attachment.sig>
More information about the MapServer-users mailing list
