[mapserver-users] RE: What is valid format for attribute color
in PostGIS ?
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Apr 12 10:17:23 EDT 2010
Rafal Magda wrote:
> On 11 April 2010 21:36, Pano Voudouris <pvoudouris at gaiocorp.com> wrote:
>> What is the actual value in the field? TEXT "255 0 0" or just "255 0 0". I
>> think only the second will work.
>> Pano
> It was "255 0 0" only, and column type was TEXT.
> I solved this problem by simply removing the first STYLE. I found that when
> using COLOR attribute there can be only one STYLE... But it is nowhere
> documented, so I consider it as a bug.
> BTW: Empirically I also found another valid format: "#ff0000".
> PS: Sorry for starting 2 duplicated threads.
Hi Rafal,
Can you please write this up as a bug. It seems like these should be
easy to fixes.
Thanks,
-Steve W
